Adapt Sky-Watcher Wifi Synscan to Orion Atlas EQ-G Mount
Equipment
4 replies to this topic
#1 MemoAstronomy
MemoAstronomy
  • Loc: Poncitlán, Jalisco, México.
Posted 10 November 2024 - 09:26 PM
Hello friends, I need your help. I have a Orion Atlas Eq-G Mount, and a Synscan Wifi of Sky-Watcher. I was reading that I can use it on my Atlas. I thing there are two ways:
1- buy a cable that works like interface between DB9 (Atlas) and RJ45 (SW Wifi).
2- create a cable that works with it.
If someone can help me, I really appreciate.
Clear skies
#2 Phil Sherman
Phil Sherman
  • Loc: Cleveland, Ohio
Posted 11 November 2024 - 08:56 AM
If you don't have the cables that came with the wifi adapter you should be able to use the coiled cord that connects the hand controller to the mount. The wifi adapter gets plugged into the same port that the hand controller uses.
#3 bignerdguy
bignerdguy
  • Loc: Lewisville, TX
Posted 11 November 2024 - 08:18 PM
The SynScan plugs into the RJ-45 handset port on the mount replacing the hand controller.  There should be no need to use an adapter cable.
#4 MemoAstronomy
MemoAstronomy
Posted 11 November 2024 - 11:33 PM
The issue is, i dont have a Hand controller, so thats why i want to try, i already have the cables that come with the Wifi Synscan :)
#5 bignerdguy
bignerdguy
Posted 12 November 2024 - 01:03 AM
The issue is, i dont have a Hand controller, so thats why i want to try, i already have the cables that come with the Wifi Synscan smile.gif
The mount has an RJ-45 connector on it that is where a HC usually plugs in at.  You plug the SynScan in there instead. The cables for the SynScan should have a RJ-45 connector included on one of the cables, this is what you use to plug into the mount.  You would not use the DB9 as this is a serial connection and is used for external control of the mount.  The SynScan is like a hand controller only it lets you use your smartphone to control the mount instead of a PC or a separate controller.
Also tagged with one or more of these keywords: Equipment
