Circular Banding in my first DSO Image
17 replies to this topic
#1 BigNickelJohnny
BigNickelJohnny
  • Loc: Sudbury, ON Canada
Posted 11 November 2024 - 11:35 AM
The other night I tried photographing the pinwheel galaxy with my Sony a7R3 and 70-200mm Sony lens with a SkyGuiderPro.
I processed the lights only with Siril on a Mac and got this linked image as a final result. This is really my first time using Siril so I have a lot to learn.  Any ideas why I am getting this circular gradient in the stretched image?  It is not apparent in the raw lights.  Is this a processing issue?n Would the result be better if I took biases flats and darks?
Looking for some direction.
Thanks in advance.
John
#2 gsaramet
gsaramet
  • Loc: Bucharest, Romania
Posted 11 November 2024 - 11:52 AM
I suppose this is a crop and the center of the image corresponds to the center of the circles?
The main thing is... you really want to do the stuff by the book. Bias, darks, flats. Until you do that, you can't eliminate causes.
So, take those calibration frames now (even if they won't be perfect) and redo the stack. If the problem goes away, that's your answer. If it changes, you have an extra data point for troubleshooting.
  • Dynan likes this
#3 Zambiadarkskies
Zambiadarkskies
  • Loc: Zambia
Posted 11 November 2024 - 12:07 PM
I suspect it is some sort of in camera processing - vignetting correction or similar.
  • sharkmelley likes this
#4 rollomonk
rollomonk
Posted 11 November 2024 - 12:28 PM
The advice above is good. Something else…. how long were your exposures? The shorter they are, the more stretching is required which can magnify issues not corrected by calibration frames…. so in addition to taking calibration frames (especially flats), perhaps you need to increase exposure time?
  • UnityLover likes this
#5 rj144
rj144
Posted 11 November 2024 - 12:41 PM
It's not sub length that matters.  It's integration time.
Edited by rj144, 11 November 2024 - 12:41 PM.
#6 Normmalin
Normmalin
  • Loc: SE Michigan
Posted 11 November 2024 - 12:48 PM
I've seen this before when I didn't treat the data as floating point but did the processing as integer.
#7 BigNickelJohnny
BigNickelJohnny
Posted 11 November 2024 - 01:26 PM
Thanks everyone for the suggestions thus far.  I will definitely try to capture the flats and biases now and redo the processing. Fingers crossed.
During this session I captured 16, 60 sec exposures for the lights and 11 darks.
Another thing I am not certain about... after the images are captured, should I be doing ANY processing of those images in LR before going to Siril??  I ask because I think that the original raw frames were underexposed (still learning here) so I bumped the exposure a bit in LR before exporting as TIF files.
As for floating point vs integer data... where is this done??? In Siril?
Thanks again for the quick responses.
#8 gsaramet
gsaramet
Posted 11 November 2024 - 02:00 PM
That's a big huge no-no. Let your raw data alone. There's nothing good you can do to your raw files in any terrestrial imaging software and a lot of bad things that are almost guaranteed to happen.
  • BigNickelJohnny and rj144 like this
#9 Normmalin
Normmalin
  • Loc: SE Michigan
Posted 11 November 2024 - 02:10 PM
I think you are doing it in Lightroom.  It exports 16-bit TIF files by default.  Don't process the raw files at all before processing in Siril and I bet this problem goes away.
#10 BQ Octantis
BQ Octantis
  • Loc: Nova, USA
Posted 11 November 2024 - 02:13 PM
I give it about 87% probability that the banding is caused by the de-vignetting tool in Lightroom. Terrestrial vignette models are not designed to be stretched with AP stretches. The cause is either insufficient bit depth (int8 or int16) or too coarse of a mathematical model (likely both).
You should be de-vignetting the final float32 stack out of Siril—and it's far better to de-vignette with flats to deconvolve the vignette (a division problem) from the light pollution gradient (a subtraction problem). And as already stated, you're best off feeding the raws into Siril for calibrating, stacking, and stretching in float32 and doing Lightroom processing afterward.
Of course, that path introduces the problem of the missing CCM…
BQ
Edited by BQ Octantis, 11 November 2024 - 02:23 PM.
  • Zambiadarkskies likes this
#11 BigNickelJohnny
BigNickelJohnny
Posted 11 November 2024 - 02:51 PM
So I went ahead and took flats and bias frames (40 each) and reprocessed all images using raw (ARW) files only and the banding is still there, albeit not as noticeable as before, but still very obvious.
I guess I will have to look at the camera and see if there is a setting or two that needs tweaking.
Thanks for all the guidance. I'll keep plugging away and learning. Clear skies.
John
#12 Noltimier
Noltimier
  • Loc: Central Ohio
Posted 11 November 2024 - 03:24 PM
Hi John.
There was a long thread on a very similar issue happening with Nikon Cameras.
Here is a link:
https://www.cloudyni...ncentric-rings/
It turns out that the colored rings in the Nikon cameras are caused by a side effect of Nikon's lossy data compression.
Something similar maybe happening with your Sony...
Hope this helps you sort it out.
Mark
  • BigNickelJohnny likes this
#13 BigNickelJohnny
BigNickelJohnny
Posted 11 November 2024 - 03:28 PM
Hi John.
Here is a link:
Mark
Thanks Mark... I was just actually reviewing my camera settings and noticed that my RAW file setting is set to Compressed. I wonder if I change this to Uncompressed if the problem goes away!?  Will have to try this next time I have clear skies.
Thanks again for chiming in. Appreciate it.
John
#14 gsaramet
gsaramet
Posted 12 November 2024 - 12:31 AM
Have you tried restacking with calibration frames and no interference from Lightroom or other terrestrial software?
#15 sharkmelley
sharkmelley
  • Loc: UK
Posted 12 November 2024 - 02:08 AM
What you have there is a very obvious case of the Sony coloured concentric polygons caused by a lens correction applied to the raw data by the camera:
https://www.markshel...d_polygons.html
Best advice is to switch off all in-camera lens corrections.  This usually improves things but may not remove them entirely.  The only permanent solution is to use a lens that the camera firmware does not recognise or use the camera on a telescope.
  • BigNickelJohnny and Zambiadarkskies like this
#16 BigNickelJohnny
BigNickelJohnny
Posted 12 November 2024 - 10:27 AM
Thank you so much!! I think I will try tonight with my Celestron NexStar 6SE instead.
Clear skies!
#17 BigNickelJohnny
BigNickelJohnny
Yes, I tried that, with no success.
#18 sharkmelley
sharkmelley
  • Loc: UK
Posted 12 November 2024 - 11:06 AM
The other thing I noticed in your image are short black bars either side of bright stars.  This is caused by Sony's lossy compression.  Use uncompressed or (if available) lossless compression.
