Sensor tilt numbers -- Siril VS ASTAP
Astrophotography Cassegrain
3 replies to this topic
#1 gokidd
gokidd
  • Loc: Central Oregon
Posted 11 November 2024 - 01:58 PM
Hello, folks.
I get wildly different estimates of sensor tilt when examining a FIT sub-exposure in Siril versus ASTAP. This is a sub-exposure, not a stacked FIT.
Both Siril and ASTAP are the most current versions.
Siril indicates only a mild tilt. ASTAP shows a horrifying convoluted graphic not even recognizable as a square.
In case it makes a difference, my setup: Celestron EdgeHD 800; Celestron OAG with ASI174MM for guiding; ASI2600MC-P for imaging; AM5 mount; coordinated by ASIair Plus.
As far as the final images being produced, I am pretty pleased with the setup. It's still early times with this rig.
Does anyone have specific experience with the sensor tilt estimates being so radically different in these two programs?
#2 Robert7980
Robert7980
  • Loc: Western North Carolina
Posted 11 November 2024 - 04:48 PM
None of them are accurate, I just use them to get get an idea about what I actually see in the images, if what you see and what the software says tend to agree then it’ll help. It will be unpredictable once you get below a threshold… So my experience is the same, just take the number with a grain of salt…
  • gokidd likes this
#3 fmendes
fmendes
  • Loc: Houston, TX
Posted 11 November 2024 - 05:04 PM
ASTAP has two methods: triangle and octagon. The second also measures back focus. A correct back focus should appear as a square; what you're seeing is (probably) both tilt and wrong back focus. Sometimes the triangle gives great results but the octagon shows bad resutls. I never saw the triangle with bad results and the octagon with good. But note that results also depend on the tracking. With less precise tracking, tilt may be all over.
  • gokidd likes this
#4 gokidd
gokidd
Posted 11 November 2024 - 05:13 PM
Thank you, gentlemen.
I looked again. ASTAP says my tilt is in the range of 50 percent! Siril says 4 percent. That is really a huge inconsistency in results between the two programs.
Felipe, thanks, I looked in ASTAP at both the hexagon and the triangle. They pretty much agreed with one another.
Also tagged with one or more of these keywords: Astrophotography, Cassegrain
