Hi all, I recently picked up a 2nd hand LX-90 with the 12" OTA on board. Thanks to Andrew's (OzAndrewJ) advice, I've upgraded the firmware to A1F7 and set about reseting, re-balancing and re-training the scope.
However, when I use it for Planetary AP, the scope won't stay where it's put. It immediately reverses direction every time I release the directional button (on every speed setting including #1) and makes the whole process extremely frustrating. On Andrew's advice I've set the Az/RA and Alt/Dec Ratios Percentages to 0% (which should stop this) and also tried a range from 10% to 50% with no effect. A link to a video showing the effect is below (turn the sound up for commentary).
https://drive.google...iew?usp=sharing
The OTA itself is able to produce some good images of the planets (for instance see hereand here) but I just cannot get the scope to stay where it's put. I admit that the focal length is quite long (around 6500 mm) and the camera sensor is quite small (1300x976 pixels) but the mount is unusable in its current state.
Apparently there's a way to tighten up the gears to reduce the amount of backlash, can anyone please point me to an online resource that describes how this is done? Failing this, I'll have to defork the OTA and use it on my Celestron CGEM mount.
Andrew
Edited by Tulloch, 11 November 2024 - 06:35 PM.
