Hi all.
I have a NexDome observatory, 8' diameter. Works fine except that the plastic block that is inserted on the dome in order to keep the sliding door from going too far (see image below) sometimes falls off when one is using too much force to close the door.
The part is only inserted (it has a slit), and I tried to glue it down with contact cement. Without much success.
Does anybody have improved on that part? I would be happy to find out... Cheers!
--Christian
