I have one, adventures in adapting to various premium spotting scopes, starting with
Optolyth 100mm fluorite
more to follow
anyone experiences?
Posted 15 November 2024 - 07:14 PM
more to follow
anyone experiences?
Posted 15 November 2024 - 07:23 PM
For a nere 300$+ it appears in the class of the Swarovski, Kowa and Leica premium zooms that cost $800-1000.
the above start at 60 degrees AF at low power, open up to near 80 degrees at max power
typical zooms start at about 38 degrees, premiums 47-50 degrees
The SVBoney starts at 57 degrees, 9 elements, one an asphere
Posted 15 November 2024 - 07:57 PM
It comes with 1.25” and a thread on 2” drawtube.
For spotting scope use the limited focus travel means the 2” tube has to go. I tried a Baader ClickLock but at 32mm tall could not reach infinity focus with the Optolyth. The thread for the SV needs to be 54mmx0.75mm. There is one Prima Lucia that is in the mail from Agena at 100 bucks, that has a 56mmx1mm female to engage the scope.
https://agenaastro.c...-stop-ring.html
CORRECTION THE ABOVE RING DOES NOT WORK! I AM INVESTIGATING
most scopes have a 42mmx0.75mm male. Agena has a ring $25 that has 54mmx0.75 male for the eyepiece end, and a 42mmx0.75mm female to engage the scope. Here I have Opticron 100mm APO (Pentax OEM), and the superior SVBoney 100mm APO spotter
https://agenaastro.c...apter-t-17.html
Edited by dougspeterson, 16 November 2024 - 02:38 PM.
Posted 15 November 2024 - 08:49 PM
Based on the very long thread about this eyepiece, it doesn’t sound like it is in the same class to me. Similar specs, yes.For a nere 300$+ it appears in the class of the Swarovski, Kowa and Leica premium zooms that cost $800-1000.
Posted 15 November 2024 - 09:08 PM
Link to that thread
https://www.cloudyni...0#entry13734817
Im in the early stages of getting it adapted, havent had a chance test or comparo
I saw a review indicating the SV equalled or exceeded the Tele Vue Delights
Edited by dougspeterson, 15 November 2024 - 10:42 PM.
Posted 16 November 2024 - 06:46 AM
....I saw a review indicating the SV equalled or exceeded the Tele Vue Delights
I'd like to see that review - do you have a link ?
I'm sceptical, in all honesty.
Edited by John Huntley, 16 November 2024 - 06:46 AM.
Posted 16 November 2024 - 11:50 AM
Let me know if reaches focus on the Optolyth 100? I use astro eps on the Optolyth 100 http://www.pt-ducks....00mm telescopes
I'm considering this ep since isn't possible to reach focus with the APM Superzoom on the Optolyth, as well as on most (all?) spotting scopes.
Edited by DRodrigues, 16 November 2024 - 11:54 AM.
Posted 16 November 2024 - 09:04 PM
The Teje Vue Delite comparison was quoted somewhere in SVBony’s propaganda. Will see if I can refind.
As for the question about whether if focuses on the 100 Optolyth fluorite, it is what I am trying to answer.
update: the 2” barrel thread into the body is hard to figure. It is NOT 54mm might be 55 or more, but it has a hyper fine thread, much smaller than 0.75mm and thus impossible to find an off the shelf ring, and I have abandoned.
I am asking Precise.Parts to quote on several rings, I expect about $100 each.
1) M56x1mm female to a T2 42mm 0.75mm for general compatability.
2) The same but with a low profile 1.25” ocular hole, thus use the 1.25 dia of the SV230.
3) M37x0.75 male to 1,25” lo profile ocular hiole w setscrew.
I am considering asking for a M56x1mm female to lo profile 2” ocular hole w setscrew, allowing use of the Tele Vue 2” to 1,25” countersunk adapter
any other adapters out there?
Posted 17 November 2024 - 08:08 AM
It's simple: remove the Optolyth ep and insert this zoom on the 1.25" version. Hold this zoom by hand (just to prevent any drop...), and see if it focus to the infinite - use also both focusers of the Optolyth. If it focus, we both will be happy. If not, see what is the serial number of your Optolyth and compare it to the ones I mentioned at the link I sent you - older models don't reach focus with most astro eps...
Posted 17 November 2024 - 01:50 PM
The SV focuses at infinity 1.25” barrel inserted in the 37mm hole all the way.
precious few mm to spare making adapter requirements tricky
A 6mm plossl focuses just at the very bottom
The Tele Vue In Travel adapter for countersunk ocular will NOT fit
i dont see the sn ranges, i dont find a sn on the scope, looks possibly a label gone
Edited by dougspeterson, 17 November 2024 - 02:29 PM.
Posted 17 November 2024 - 02:19 PM
Nice it reaches focus!...
You have the straight version or the 45º of the Optolyth?
The sn is at the "foot" of the spotting scope, eyepiece side, over the plate of the tripod head.
Sorry, the sn issue is mentioned at http://www.pt-ducks....#Our experience - "(beware that an older telescope (serial number 125528) of the same model doesn’t have enough focus range to this eyepiece. Even on my telescope (serial number 126475) it’s very close to a limit – always test the eyepiece on the telescope before buying it…)"
Posted 17 November 2024 - 03:50 PM
Sn 130773
Angled version, for astronomy
I love this scope, just want more versatility than the 2 to 1 30-60x
I presume they dont sell with the 3 to 1 zoom is some compatibility problem. Anyone tried with? Will have the right threads! Might satisfy me.
Too bad the 1.25” Astro adapter no longer available; with set screw added would be the answer.
hopefully Precise.Parts will have a quote for me. Will report here
Edited by dougspeterson, 17 November 2024 - 04:42 PM.
Posted 17 November 2024 - 04:39 PM
The 30-60x Optolyth zoom makes no sense... If you read the link I sent you, you will see that I have the older 20-60x zoom for the 100 and last 2 versions of the 20-60x zoom for the 80 model that result on 30-90x on 100 - I used always one of these for my day-light use! The best quality image, with zooms, is with the Baader zoom (result on 26-76x) and you can use a 1.6x barlow cell with it to achieve a equivalent 42-126x. 5mm astro eps also work great! I had a Radian 4mm but didn't liked it for my day-light use.
It's a pity that the last owner of Optolyth factory stopped the sport optics production, since the relation of quality/price was very good. However, I recommend you to not try a Kowa 99 or a Swaro X95/X115... The use of this zoom with the Optolyth 100 will result closer to the mentioned brand models, at least on AFOVs - will see the image quality - I hope this zoom will also reach focus on my Optolyth 100 straight version...
Posted 17 November 2024 - 06:37 PM
Thanks! I am in the market then for the 25-75x!
hey how are you fitting the Baader to the 100?
Edited by dougspeterson, 17 November 2024 - 07:28 PM.
Posted 17 November 2024 - 08:34 PM
Hard to tell but you have the original M37 to 1.25” astro adapter? Looks like if Precise.Parts can make me the equivalent this will be my final answer
The Opto 20-60x zoom has too restricted a field. The Baader and the Sv230 are the answer
Edited by dougspeterson, 17 November 2024 - 08:36 PM.
Posted 18 November 2024 - 03:35 AM
I had sent a couple questions to SVBony re the SV230 and their 100mm APO spotter,
and their answer in part:
In addition, the two-inch thread size of SV230 is M48.
If you want to install SV230 on SA401, we do not recommend that you do so.
The SV230 eyepiece is prone to out of focus when used with a birding scope.
Once again, we apologize for the inconvenience caused to you.
Posted 15 May 2025 - 02:49 AM
We have launched a dedicated adapter ring specifically designed for the compatibility between SV230 and SA401. For more details, please refer to the following link:https://www.svbony.c...-adapter-sv230/
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
