I have a Pegasus Ultimate Powerbox v3 with a USB3 port that has broken. The blue centerpost has broken off the port (I still have it), exposing 4 wires that are normally housed in that centerpost. See photo below. The USB# port is the one that wires the PUPBv3 to my onboard computer; it is essential to my rig as built.
Pegasus' 2 year warranty does not cover this. Local repair shops would need to send it off for repair, as would Pegasus. Likely cost including shipping = ~$80. The part only costs ~$1.
This happened to me once before with my ASI2600 camera. I had to get a whole new circuit board for the camera just to replace the USB3 port! I thought this time I'd like to try and repair it by desoldering the broken part and soldering a new port in its place. A good skill to have.
I've never soldered circuit boards, but have soldered a number of household electrical repairs, and have the equipment - and in pondering this possibility I have watched a few videos, found a few scrap circuit boards and have practiced desoldering and soldering with growing success, using both a hot air gun (for desoldering) and a soldering iron station to solder. My impression is this should is a skill within my reach. I could, of course, be wrong. ;-)
There are three steps to this process that are emphasized on the videos:
1) Desolder the current port
2) Clean the holes (all 11 of them!) of any residual solder
3) Solder in the new port
I intend to use a soldering heat gun for #1, and the soldering iron with soldering wick for #2 and the soldering iron for #3, all with lots of flux
The port is helpfully located near the corner of the board (see photos- the black cable is attached to the USB3 port) and the majority of the board can easily be isolated and protected from the heat gun air with foil. The hot air would be traveling outwards towards the corner of the board.
Questions for anyone who has worked on a Pegasus (or similar) board:
- I notice the board itself has a black coating on both sides. Is that a conformal coating of some sort? Would it complicate desoldering or soldering?
- Would you have any concerns about my proposed desoldering process (with the heat gun)? I have to have some way to heat up all 11 soldered connections at the same time to remove the current port (unless I was to manually clip off all the port connections and then remove the soldered stubs one at a time).
I'd be grateful for recommendations from any of you who have tried this with your astro equipment.
Thanks!!
Geoff
