Hi there, and welcome to the hobby!
It’s great to see you diving into astronomy! Both the Celestron GP-C8 and the Orion Skyview 8” can be decent options, but there are a few things to consider.
Regarding the Celestron GP-C8, you’re right that it’s an older setup—produced a few decades ago—but it’s still a solid, reliable telescope if it’s in good condition. The optics (the 8” SCT) can deliver great views of planets, deep sky objects, and the Moon, but make sure to check the condition of the optics and mount before buying. If it's priced reasonably, it could still offer good value, especially if the mount and tripod are still functioning well.
The Orion Skyview 8”, on the other hand, has a bit of a mixed reputation depending on the specific mount and setup. Some people report issues with the mount’s stability and tracking, so you’ll want to carefully check the condition of the mount, particularly if it's a few years old. That said, $600 for the telescope and accessories does sound like a pretty good deal if everything is in working order. It might just be a bit more of a challenge to get it set up and performing well if the mount is not as solid as you'd like.
If you’re set on getting an 8” aperture, I think either of these could work for you, but you might also want to consider newer scopes or mounts, which could offer better stability and ease of use—especially if you plan to do astrophotography or want something that’s easier to set up.
Good luck with your decision, and enjoy your journey into the stars!
