Binoviewing The Deep Sky - An Invitation to Research
17 replies to this topic
#1 JoshUrban
JoshUrban
  • Loc: Rustburg, VA
Posted 01 December 2024 - 07:05 AM
Binoviewing is usually reserved for dedicated lunar and planetary observers. But could it be an overlooked tool for the rest of us? Do binoviewers on a telescope outperform mono-viewing for deep sky work by boosting contrast and reducing visual noise? They offer a spectacular visceral experience, but are they useful for serious work?
Click here to view the article
  • lanndonkane likes this
#2 fghsocwk
fghsocwk
  • Loc: Raleigh, NC
Posted 01 December 2024 - 11:15 AM
Thank you for the report, Josh.   With the increasingly cooler weather (good for seeing, bad for endurance!) I was looking for something to "push" the seeing window and was going to trying my binoviewer.  Frank
  • JoshUrban and UnityLover like this
#3 Jon_Doh
Jon_Doh
  • Loc: Just South of Pluto
Posted 02 December 2024 - 09:34 AM
Thank you for sharing your experience.  You answered many questions I've had about binoviewing.  But I would like to see how binoviewers would do on dso's with a 5 or 6 inch refractor.
#4 JoshUrban
JoshUrban
  • Loc: Rustburg, VA
Posted 02 December 2024 - 03:15 PM
Great question, Jon!  I did some preliminary viewing after this was written with a 102mm, but found things too dim with that platform. Would love to try it with a 5 or 6!  If you've got one near Lynchburg, VA, bring it by and we'll do some looking!
  • Jon_Doh likes this
#5 ayadai
ayadai
  • Loc: Northern Mariana Islands
Posted 02 December 2024 - 04:07 PM
Thanks for the article! Here's my take from the cheap seats:
In our bortle-4 skies using the Arcturus binoviewers with the stock eyepieces on the Startravel 102, most DSOs below magnitude ~6.5 are, to my eye, close in brightness, but more detailed and colorful, than when viewing them with my Celestron X-Cel LX 25mm or my Celestron Omni 32mm Plosl. For objects above said magnitude, the monoculars edge out the binoviewers, especially with focal lengths of 12mm and below.
  • JoshUrban likes this
#6 JoshUrban
JoshUrban
  • Loc: Rustburg, VA
Posted 02 December 2024 - 08:13 PM
Thanks for the report!  I'm wondering if there's a light threshold where they become useful for DSOs. From doing an "unofficial" session with my 102mm f/11 TS optics ED refractor, they were underwhelming. The 8" dob seemed best, but at this point, it's anecdotal. Thanks for seconding my findings with an 100mm-class instrument.
#7 ayadai
ayadai
Posted 02 December 2024 - 10:16 PM
I think one crucial difference is that the Startravel 102 is f4.9 VS f11 for the TS optics ED.
Edited by ayadai, 02 December 2024 - 10:16 PM.
#8 CrazyPanda
CrazyPanda
Posted 03 December 2024 - 11:51 AM
"Binoviewers are only for lunar and planetary work."  The binoviewer is a lot of extra glass for starlight to travel through, including a beam splitter and an extra eyepiece. Throughput must surely be reduced.  I'm a fan of minimal glass rigs. This seems the opposite.
Contrary to popular opinion, light loss/throughput reduction was minimal, if noticeable at all.
The issue isn't with the extra optics, it's that by necessity, each eye only receives 50% of the light.
It's certainly not my experience that the light loss doesn't change. It's DRAMATICALLY dimmer in a binoviewer than monoviewing. Binoviewing DSOs in my 14.7" feels like monoviewing with a 10" but with a bit more contrast.
What you gain from binoviewing is signal reinforcement and therefore contrast, but in my experience this does not make up for the 50% light loss to each eye.
This is not qualitative either - I can see fainter threshold galaxies monoviewing than I can binoviewing at the same magnification/exit pupil.
The Orion Nebula looks more contrasty binoviewing, but I can trace the fainter extents of the nebula out farther when monoviewing.
For me binoviewing DSOs just doesn't work and is net worse than monoviewing through the same instrument.
#9 JoshUrban
JoshUrban
  • Loc: Rustburg, VA
Posted 04 December 2024 - 08:13 AM
Howdy, CrazyPanda, good to see you on here.  You bring up excellent points, and a question that I don't know the answer to: does the brain "re-add" the split beam so it's nearly the same as the unsplit?
In other words, is the equation:  Original light,  Divided in Half, 50% in each eye = 50% dimmer perceived image
OR:
Original light, Divided in Half, 50% in each eye, summed back together by brain (with slight loss) = 3% dimmer perceived image
And if so, is the boost in contrast enough of a benefit in some cases to offset it?
Word on the street has the first equation right. My experience with the 8: f/7.5 dob and a dark nebulae hews closer to the second.
Perhaps there's also a factor of knowing what I'm looking for. If I see a dimmer, but clearer, picture of an object in stereo, and then switch back to a brighter mono view, maybe that's a way to get more mileage out of it.
We both subscribe to the "ever last bit helps" school of deep sky observing, and this stereo observation of B86 has puzzled me.  I'm realizing I've been overlooking the optical train after the eyepiece, too.  (Eye and brain.)
I'm looking at this article as an open-source call to research. Appreciate you sharing your findings here!
#10 lwbehney
lwbehney
  • Loc: Indiana
Posted 04 December 2024 - 12:29 PM
I have read somewhere that binocular summation adds about 1.4 times the perceived amount of light grasp. That would mean objects should be perceived as about 30% dimmer than when viewing them with one eye. If that holds true for a given observer, then using a binoviewer would be equivalent to reducing your telescope  aperture by 83% in light-gathering capacity.
#11 ayadai
ayadai
Posted 04 December 2024 - 05:23 PM
1/1.4=.71; 100-71= 29 OK. Where does the 83% come from?
  • lwbehney likes this
#12 lwbehney
lwbehney
  • Loc: Indiana
Posted 04 December 2024 - 06:38 PM
You are correct that the light gathering affect is 29% less, but the specific telescope aperture reduction to achieve that 0.71 effect is the SQR(.71) = 0.84. I rounded it down to 0.83 based upon my 30% dimmer assumption and hence SQR(0.7).  The brightness diminishes at the rate of the square of the aperture reduction. So a six inch refractor using binoviewers would probably have the light gathering equivalent of a 120+ mm refractor, but would have better contrast and better resolution than the 120 mm refractor and would also manage a higher magnification at any given exit pupil. That would help contrast also.
  • ayadai likes this
#13 VAviewer
VAviewer
  • Loc: Central Virginia
Posted 05 December 2024 - 10:55 PM
Omg josh? we just talked today.
I don't think you mentioned the specific brand /model of binos you were using, that could be insightful to your results. I've also heard some talk about using binoviewers to compare different EPs, if you ever get the chance that could make an interesting write-up. -A
#14 careysub
careysub
  • Loc: Rancho Cucamonga, CA
Posted 08 December 2024 - 04:45 PM
To investigate the effect of F-ratio try putting an aperture mask over your 12.5" F/5. An 8.3" mask will match the f/7.5 of your other scope. And you could try 6.25" to investigate f/10.
With the Portaball build it may not be easy to quickly swap the mask in and out, but you might be able to with your other scope, and test a 6" mask for f/10.
#15 Sebastian_Sajaroff
Sebastian_Sajaroff
Posted 13 December 2024 - 01:37 PM
I'm one of those that struggles to merge both images on binoculars, microscopes
and binoviewers (phoria).
Make sure you don't have trouble using plain binoculars, otherwise there's some risk the
same issue may reappear on binoviewers. In that case, make sure you have a solid refund policy before swiping your credit card.
For those who don't have the issues -> enjoy the view, it's really worth it.
#16 30mmgunpilot
30mmgunpilot
Posted 15 December 2024 - 11:49 PM
Great research project! CrazyPanda has an extremely valid point on the brightness being halved for each eye and the resulting dimness affecting how much of the “faint fuzzy” you can see.
That being said, using two eyes can help mask the physiological limitations of an individual eye. Astigmatism frequently varies between individual eyeballs (my right eye is slightly more astigmatic than my left, but merged eyes cause the single eye astigmatism to disappear (brain processing). Dioptrix is great…for the eyepieces that accept it. Another potential (?) benefit of two eyes: blind spots caused by the optic nerve in each eye could be slightly different in size/shape/structure, so binocular overlapping coverage could be a possible advantage.
I’ve also found “halving the brightness” works pretty darn good when you have a brighter object in the same FOV…that might be part of the apparent increased contrast gained from binoviewing.  I look forward to reading more as you continue the research!
#17 lwbehney
lwbehney
  • Loc: Indiana
Posted 21 December 2024 - 07:40 PM
Yes indeed. Jupiter is too bright in any aperture > 6 inches and binoviewers really help calm that down to tolerable levels of light intensity.
  • 30mmgunpilot likes this
#18 musikerhugh
musikerhugh
  • Loc: Hartford, CT
Posted 29 December 2024 - 10:40 PM
My own binoviewing experience is with a Denkmeier Binotron 27 with an Obsession Classic 15" f4.5 reflector.
With this setup, where there is no dearth of incoming light, there is no question that the binoviewer provides a superior visual experience for nearly every kind of DSO. Binocular vision both magnifies objects and increases contrast and therefore enhances detail. Any reduction in the number of photons reaching each eye simply doesn't matter to the brain: if I can see it with my 15" scope, it will look bigger, brighter and more detailed with the binoviewer. Bright objects like the Dumbbell and Swan Nebulas seem to float before you in 3D and when the Andromeda Galaxy fills your field of view, the reduction in brightness probably helps to reveal the subtle gaps between the spiral arms. Dim galaxies in the Virgo Cluster - Messiers and the dozens of smaller NGCs between them - are easier to distinguish from each other, and even the far distant galaxies of Stephan's Quintet are easier to pick out. And then, of course, there is the immersive nature of the experience, which you can't put a number on.
Some features of the Denkmeier in particular that enhance the experience are the ability to switch between 3 magnifications using sliding tabs as well as the ability to switch from unfiltered viewing to one of 2 filters also using a slide mechanism. The eyepiece holders also adjust focus independently and the workmanship overall is top notch. Customer service is unmatched - personal and generous.
The downsides:
1. in my scope, the main issue is the absolute field of view. The 21mm 65º EPs yield an absolute field of view that's a little less than half a degree at the lowest power, and the 32mm 50º EPs FOV is only marginally bigger (because of the Barlow lens and the added distance needed to come to focus, the functional focal length of the EPs is cut by about half). Since I only do star-hopping with a Telrad, I often use a single 20 or 31mm wide angle EP to search for small dim objects before switching to the binoviewer to study them - the wider field keeps guidestars in view and for me the "2D" view with a single eye helps non-stellar objects stand out more in a busy field. Obviously, this also limits how I can view extended objects like the Veil or Rosette Nebulas - and it also means I have to move my scope more often to keep them in view.
2. The weight. It's heavier even than my TeleVue 31mm Nager and I do need a counterweight - a filled 16oz water bottle - at the bottom of my scope when I use it below 45º azimuth. Remember, this is an Obsession Classic, all wood construction, so the mirror and rocker box already have heft. I have also used it on my 8" Orion Dob with a heavier magnetic counterweight without any issues.
3. The cost. The Denkmeier is an expensive purchase, but for a serious observer, it could be considered a bargain. Complete with 2 pairs of EPs and extenders to reach focus in my large Dob, the total cost was about the same as 2 large Televue EPs (+/- $1500). And, it transforms my 15" Obsession into a completely different kind of instrument - basically the equivalent of a pair of high quality 130-300 x 270 binoculars!
