Need help with diffraction spikes using Redcat 51: did it become worse?
Astrophotography Beginner Refractor
8 replies to this topic
#1 piyushCK
piyushCK
  • Loc: San Diego, California
Posted 02 December 2024 - 06:48 PM
Hello,
I am a novice astrophotographer.
I use a Redcat 51 with ZWO ASI294MC Pro.
Mount: i-Optron Skyguider pro and guiding with ZWO ASI174MM Mini Guide camera
I was shooting Horsehead Nebula yesterday and noted very sharp diffraction spikes around Alnitak and one more bright star.(My guiding was not good.)
Back in February, I observed the spikes around Alnitak were much smoother both in a single exposure and the stacked result.
I am worried if there is a scratch on the scope that's causing this. Yesterday, before heading for the imaging session, I cleaned the aperture using a lens spray cleaner and a micro-fiber cloth.
I had to make multiple attempts due to smudges left behind after each clean-up.
I'd do the cleanup more gently the next time or have an expert do it.
I have attached the results from
1. Yesterday's session- Horsehead Nebula
2. A month ago-Pleiades
3. Feb, 2024-Horsehead Nebula
https://drive.google...?usp=drive_link
Kindly let me know if I inadvertently messed something up with the scope.(or what I am observing is normal)
Thanks and regards,
Piyush
#2 UnityLover
UnityLover
  • Loc: Suffolk County
Posted 02 December 2024 - 07:16 PM
Hello,
Thanks and regards,
Piyush
By lens, you meant the objective, right?
If so, it may have left a film, which can reflect a bit of light. Maybe wipe it down again? Also, before you do that, its possible that cloth and the liquid are far too rough and coarse for the objective, and may have damaged the coatings. Not sure though.
  • piyushCK likes this
#3 piyushCK
piyushCK
Posted 02 December 2024 - 07:23 PM
I first used an air blower to remove dust. Then, I used a glass lens cleaner(for eyeglasses) and a microfiber cloth. I hope it's just a film.
I only cleaned the aperture portion of the scope- the glass on the front.
  • UnityLover likes this
#4 UnityLover
UnityLover
Posted 02 December 2024 - 08:01 PM
Was the cloth cheap like for eyeglasses, and smooth? or fuzzy?
#5 John Berger
John Berger
Posted 02 December 2024 - 08:04 PM
I don't see anything wrong with your stars besides the elongation from bad guiding
just, make sure your air blower is not the chemical-spouting type, just use the one that has the tear drop shape and uses air from the atmosphere
and also, when you use a microfiber cloth, don't press into the glass, just gently streak the areas you want to clean, and make sure it's meant for wiping lenses
and, try not to breath onto the glass - it happened with me that I once was trying to remove a haze from my objective lens, with a cloth, but I noticed it wasn't going away and it looked to be getting worse; I thought: "hmmm, that's weird"; I then noticed that it was my breath, because my face was like 6 inches away lol.gif ; I was 6 inches because I wanted to see what exactly I was cleaning off; so maybe try to use a face mask (not the valve type) or just try to hold in your breath for a few moments, and also I would recommend gloves, because finger oils can get onto the microfiber cloth, and can be smeared on the glass accidentally.
also, your cleaning solution should be specifically designed for wiping telescope glass, because normal cleaning solution might remove coatings
or if you decide just to use water, make sure it's distilled
Edited by John Berger, 02 December 2024 - 08:44 PM.
#6 piyushCK
piyushCK
Posted 02 December 2024 - 08:54 PM
It was a regular eyeglass cleaning cloth:
https://postimg.cc/sG2TrNwt/0751d4f3
I did not know. Should have used a better material.
#7 piyushCK
piyushCK
Posted 02 December 2024 - 08:57 PM
Thanks a lot! ☺️I’ll keep these in mind.
Could you please recommend a good cleaning solution/cloth for telescopes?
Edited by piyushCK, 02 December 2024 - 08:57 PM.
  • John Berger likes this
#8 John Berger
John Berger
Posted 02 December 2024 - 09:06 PM
I would recommend this kit https://www.highpoin...aning-kit-93576
Celestron should know very well what they're doing
and the reviews are good
it's not for mirrors, just glass
and plz be careful, be always gentle
#9 piyushCK
piyushCK
Posted 02 December 2024 - 11:05 PM
Thank you so much. Just ordered.
Also tagged with one or more of these keywords: Astrophotography, Beginner, Refractor
