Dark Sky Site - Culling Subs with Clouds
7 replies to this topic
#1 KTAZ
KTAZ
  • Loc: Scottsdale, AZ
Posted 03 December 2024 - 09:02 AM
Hello all;
I have my remote observatory up and running and have found that the identification of high clouds in subs is not as easy as it was in a light polluted environment. At my home location (B6) clouds can easily be seen by Blinking my subs...if I get white gradients in the frame...clouds. Easy peezy.
At the obsy (B1) clouds have no ground effect light to reflect back...they are literally black. So seeing them in subs to cull them out is a bit more difficult.
What techniques (aside from Blink) do some of you remote site APr's use to identify and cull subs that have high, thin clouds?
#2 Michael Covington
Michael Covington
    Author
  • Freeware Developers
  • Loc: Athens, Georgia, USA
Posted 03 December 2024 - 09:03 AM
I think the general idea is that software uses the star count as a criterion.
#3 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 03 December 2024 - 09:44 AM
PixInsight's Subframe Selector process provides a wide variety of metrics on your subs.  The graphs show the change over time.
The star count graph should give you a good idea of when the clouds were causing problems.  SNR should help too.
-Dan
#4 jml79
jml79
  • Loc: Belleville, Ont, Canada
Posted 03 December 2024 - 09:49 AM
SkyStory did a great video on SubFrame selector and he has very dark skies too. I use his 4 criteria and have noticed a solid improvement in my stacks vs just using blink.
https://www.youtube.com/@SKYST0RY
  • KTAZ likes this
#5 smiller
smiller
  • Loc: Vancouver Washington (not BC!)
Posted 03 December 2024 - 10:48 AM
Lots of good suggestions already.  One more:  I use NINA and I have the number of stars (along with HFR and other capture stats)  recorded in the file name which makes it very easy to identify the images with low star counts (or poor HFRs) just by the file names.
  • Michael Covington, steveincolo and KTAZ like this
#6 sn2006gy
sn2006gy
    Vendor - Rockchuck Summit Observatory
  • Loc: Austin, TX
Posted 05 December 2024 - 09:28 AM
NINA also has a great plugin "Session Metadata" that will dump the metadata.csv into your imaging folder with the following data:
ExposureNumber,FilePath,FilterName,ExposureStart,Duration,Binning,CameraTemp,CameraTargetTemp,Gain,Offset,ADUStDev,ADUMean,ADUMedian,ADUMin,ADUMax,DetectedStars,HFR,HFRStDev,FWHM,Eccentricity,GuidingRMS,GuidingRMSArcSec,GuidingRMSRA,GuidingRMSRAArcSec,GuidingRMSDEC,GuidingRMSDECArcSec,FocuserPosition,FocuserTemp,RotatorPosition,PierSide,Airmass,ExposureStartUTC,MountRA,MountDec
217,D:/Imaging/Barnard's Loop - Horsehead/2024-11-26/LIGHT/2024-11-26_23-37-52_L_-10.10_120.00s_0217.fits,L,2024-11-26 23:37,120,1x1,-10.1,-10,100,50,720.5926,1147.0938,1111,706,65535,3071,1.7484,0.1631,10.076543576457915,0.4255764350999695,0.1002,0.5513,0.0804,0.4423,0.0598,0.329,34965,21.23,179.2897,West,1.4233,2024-11-27T05:37:52.1855321Z,85.84385354568914,-1.4741889465746498
  • KTAZ likes this
#7 KTAZ
KTAZ
Posted 05 December 2024 - 04:10 PM
Great suggestions. I have already implemented the star counts into my file name, but I also plan to play with the Session Metadata plugin this weekend.
#8 jml79
jml79
Posted 06 December 2024 - 08:28 AM
I like adding the FWHM to the filename. I believe you have to have Hocus Focus installed to do this but who doesn't use Hocus Focus. Anytime it can't determine a FWHM due to clouds etc it puts NaN in the filename and that lets me delete all of those nasty subs in seconds with a quick command line or file search.
