In each of the panels below (full 1600px width can be accessed by selecting the image set) the LEFT hand image is processed using BiggSky Blind Deconvolution with the default settings with the exception of adjustments to the psf radius and the Guard Band settings. The default settings for both these parameters are 32. The comparison images are processed entirely in Wavesharp. The center image is what I consider "nominal" sharpening. Layer 1 = Strength 0.150 and 100%, Layer 2 = Strength 0.130 and 40%, Layer 3 = Strength 0.110 20%. The right hand image is what I consider to be "aggressive" sharpening. Layer 1 = Strength 0.180 and 100%, Layer 2 = 0.150 and 40%, Layer 3 = 0.120 and 20%. FFT Denoise and RGB Balance along with a 20% Saturation bump have also been applied to the images (including the BiggSky processed images). For the two images processed with psf radii smaller than the default value of 32 I have applied wavelets to the image following deconvolution. The values used in those two cases are presented with the image set below. Finally the comparison composite images were assembled in Paint Shop Pro in which curves and white balance were applied to ALL of the images.
First set is BiggSky Blind Deconvolution with psf = 8 and Guard band = 8. This image was sharpened in Wavesharp using Layer 1 = 0.100 and 100%, Layer 2 = 0.100 and 40% and Layer 3 = 0.100 and 20%.
The next set is psf = 16 and Guard band = 16. This image was also sharpened in Wavesharp using just Layer 1 = 0.100 and 100%
This image is psf = 24 and Guard band = 24
This image using the default settings of psf = 32 and Guard band = 32. No additional sharpening was performed on the image.
This image using psf = 64 and Guard band = 32 Previous work on earlier data convinced me that a Guard band larger than 32 was unnecessary.
Finally, this last image uses psf = 128 and Guard band = 32.
In summary, my conclusion is that BiggSky in the current version is a good option for sharpening Jupiter images. The default settings of psf = 32 and Guard band = 32 yield acceptable results. Increasing the psf radius quickly begins to yield less satisfactory results and I think there is some value in combining blind deconvolution with wavelet sharpening instead of relying solely on blind deconvolution for sharpening.
I'm going to spend some time working with some Saturn data next as Con gets some spectacular results with his data using deconvolution as an alternative to wavelets (he uses Astra Image if I recall correctly) and I'm curious if blind deconvolution can be effective at bringing out finer details in the rings than wavelets does alone on my data.
Edited by dcaponeii, 03 December 2024 - 03:48 PM.
