Hello!
I had long planned to optically test my star diagonals -- for no other reason than that I believe this could be something which I would have fun doing. I have been very curiously reading the threads on star testing and DPAC that I could find here, and in this thread I plan to document my progress, and ask questions along the way.
As a very first step, I'd like to attempt contact testing with an optical flat, simply by placing a few of the old, cheap prisms I own on a clean optical flat, wait till fringes form under monochromatic light, and see how different the patterns are between the different diagonal prisms.
For this task, I bought and old and somewhat abused optical flat, 4 inch in diameter, labelled "accuracy +- .0000010" , which I think translates to 1/20 wave error. The flat has some scratches and a chip, the figure may hence not be accurate any more. But, I am just trying to learn here, and this flat should provide an affordable attempt for me to find out if I do enjoy indoor optics testing at all.
The first obstacle is a source for monochromatic light. A low-pressure sodium lamp is not an option given the cost, and (at least locally) I only found LED energy-saving light bulbs but no CLF blubs, though I could order a CLF bulb online somewhere.
I wanted to ask, has someone tried the combination of a green LED and a Baader "Solar Continuum" filter? The filter has a band width of 10nm ; the green led likely around 20-30nm ; if those are slightly offset, that could make for an even narrower band width, perhaps sufficient to see the fringes? Did anyone try this by any chance already? (I do have the filter, I'd just need to obtain a bright-enough green LED).
Cheers
ngc
