While looking through the Digitized Sky Survey, I saw a tiny hint of what looked like HII. It was invisible with a linear stretch applied to the survey image. With a hyperbolic arcsine stretch applied and the image brightness turned up, a small "blob" of what looks to be HII appears, about 5' by 5' in angular size. It's in the constellation Cepheus at 22 44 51.350 +60 49 03.41 (J2000). The star in the middle of the attached image is HD 215575 (I haven't been able to tell if it's just co-located with the HII region or if it's actually inside it.)
I initially thought this object was quite probably catalogued, so I checked SIMBAD and the VizieR databases. Nothing turned up. I searched the Sharpless catalog, as it's intended to be a comprehensive survey of all HII regions north of -27 degrees declination. While there are several Sharpless objects in the region, including one only about a degree south, this object is not in the Sharpless catalog. I searched for any references of an HII region/any nebula near HD 215575, and nothing turned up. I looked at all the papers that SIMBAD stated referenced HD 215575, and there was no mention of this HII region.
I am somewhat doubtful that this region is truly undiscovered, on account of its size and brightness. I would have thought that it would be in the Sharpless catalog. Perhaps it is just part of another HII region, a part that just happens to be centered around HD 215575. Still, I am unable to find any reference to this object. Any help in tracking it down, or in determining if it truly is uncatalogued, would be appreciated.
Edited by Irido, 05 December 2024 - 02:04 AM.
