Hi! I've been pondering different "super portable" options, from binoculars and monopod to small refractor and carbon fiber tripod. Since I want something more than a 10x50 and binoculars get heavy and big really quick, I am settling towards a AT72EDII. I'd like the most powerful eyepiece to be 4mm to reach ~100x. I should mention that I don't plan to do astrophotography, this is supposed to be a compact visual setup that I can take in a backpack for small hikes, in the car, in a flight, etc.
This refractor is 30cm long and weighs 2.17kg which is the level of portability I'm aiming for. With that in mind, I've been eyeing the following tripods:
They are all less than 60cm and 2.4 kg so that also fits perfectly. For the head, I was thinking either:
My questions are:
1) I know the Gitzo would probably be the best, but I would also like to not spend $500 dollars unless I have to! Are the other options reasonable or will I have a bad time with shakiness at 100x?
2) This would be my first telescope (Although I've used my Meade 10x56 for a year!) and I'm not sure I understand how the mount heads fit into the tripod. Do I need any extra equipment? Or any head I listed would fit directly into any of the tripods? It seems the DSV-M might need an extra column?
3) This is an extra question but I was wondering if the Astro-Tech 4mm UWA 82° 1.25" and the Astro-Tech 18mm 1.25" Paradigm Dual ED Eyepieces would be a good beginner choice for the AT72EDII.
Thanks so much for all your help!
Edited by Kerrschild, 05 December 2024 - 02:00 AM.
