How long do you let your reflector cool down?
45 replies to this topic
#1 RobVG
RobVG
  • Loc: White Rock BC
Posted 05 December 2024 - 12:36 PM
Starting to have nights below freezing here.
Edited by RobVG, 05 December 2024 - 12:36 PM.
  • sheath likes this
#2 Inkie
Inkie
Posted 05 December 2024 - 12:53 PM
At least and hour, but it could be closer to two if you go from home environment to fully outdoors.  I keep my 12" Dob in an out-building, unheated, garage, and I can use it within 30 minutes typically.
  • RobVG, izar187, Illinois and 2 others like this
#3 Mike Q
Mike Q
  • Loc: Monnett Ohio
Posted 05 December 2024 - 01:35 PM
My scopes are in a well ventilated outbuilding.  As a result they are always within a degree or two of ambient air temp.  So by the time I roll it out and set it up its pretty much ready to go.  Going from the house to outdoors, you will have a solid hour at a minimum
  • izar187 and sheath like this
#4 sevenofnine
sevenofnine
  • Loc: Santa Rosa, California 38*N., 122*W.
Posted 05 December 2024 - 01:36 PM
Setting it out at dusk works for me. It's easier than trying to navigate in the dark too borg.gif
  • RobVG, zizzapnia, HopeStar7 and 1 other like this
#5 sheath
sheath
Posted 05 December 2024 - 01:44 PM
If you have a dew issue, waiting until after the dew point to uncover might not be a bad idea.
I've got a Gizmos cover, and one evening took it off a bit too soon. lol
It was in the low 20s by the time I got outside, and this was the result.
  • Jon Isaacs, Illinois and sevenofnine like this
#6 Tony Flanders
Tony Flanders
  • Loc: New Lebanon, NY and Cambridge, MA, USA
Posted 05 December 2024 - 02:19 PM
That looks the way a telescope should in the winter. There's a very slight accumulation of frost on the outside, which has zero effect on the telescope's performance. Frost gets to be annoying when the scope looks solid white instead of black flecked with white, and you can scrape large volumes of frost off with your fingernails. But even in such situations my Dobs' mirror usually remain unaffected.
In any case, there's no such thing as "waiting until after the dew point." The accumulation of dew -- or in this case frost -- increases steadily throughout the night in normal conditions.
I prefer to leave my Dobs out for at least an hour before using them, but that's typically not an option which I'm in the city, in which case there's nowhere safe to leave the scope outside, and in any case I will be driving to a remote location. If my scope isn't fully cooled, I concentrate on objects that can be viewed well at low magnifications.
A built-in fan can be a huge boon.
  • RobVG, happylimpet and radiofm74 like this
#7 sheath
sheath
Posted 05 December 2024 - 02:32 PM
Try grabbing a frozen eye piece or focuser with bare fingers. lol
If I wait until the temp crosses the dew point at sub freezing temps none of the components get frosted.
Might be different for your location?
Here is a picture from the night before.  Same basic conditions I just waited until later to pull the cover off.
  • Illinois likes this
#8 Sebastian_Sajaroff
Sebastian_Sajaroff
Posted 05 December 2024 - 02:49 PM
My 6" F/8 Dobson took 30-45 minutes to cool down during Canadian winter nights.
In autumn and spring it was close to 15-20 minutes.
You’re ready when the view stops boiling like crazy.
  • RobVG, tcifani and sheath like this
#9 SeattleScott
SeattleScott
Posted 05 December 2024 - 02:55 PM
Larger aperture takes longer. For 8” or so, an hour is probably plenty. Personally I would start observing right away, and just focus on lower magnification targets first, then medium power targets, and after 45 minutes of that the mirrors should be acclimated for high power.
  • RobVG, Don H, Sebastian_Sajaroff and 1 other like this
#10 BIG
BIG
  • Loc: Arizona High-Country
Posted 05 December 2024 - 03:47 PM
Another recommendation for setting up equipment at dusk with some helpful twilight, and coming back an hour or two later to observe. In my case, after my wife and I and our three pups have finished dinner, which usually results in all of them settling in for the evening and leaving me undisturbed.
  • RobVG, Sebastian_Sajaroff, Bulldawg54 and 1 other like this
#11 AlamoBob
AlamoBob
  • Loc: Alamogordo, New Mexico, USA
Posted 05 December 2024 - 05:02 PM
In the High Desert, I think the temps after sunset can fall faster than the glass can keep up with.  I guess I'll know when I actually BUILD my telescope!
  • sheath likes this
#12 RobVG
RobVG
Posted 05 December 2024 - 05:03 PM
A new tarp is in order....
  • sheath likes this
#13 rrpallechio
rrpallechio
  • Loc: Tumwater, WA, USA
Posted 05 December 2024 - 05:08 PM
I set my SCT up outside well before sunset.
  • Mike Q and sheath like this
#14 Sebastian_Sajaroff
Sebastian_Sajaroff
Posted 05 December 2024 - 06:07 PM
That’s a great idea, it’s always easier and safer to setup your telescope with some light outside.
  • spaceoddity and sheath like this
#15 Keith Rivich
Keith Rivich
  • Loc: Cypress, Tx
Posted 05 December 2024 - 07:14 PM
My "cool down" time is covered in the set up and collimation time. So once collimated I am ready to go. Keep in mind I have open truss scopes so there is very little chance of seeing tube currents that can plague closed tube scopes.
If the temperatures are dropping so fast the mirror can't keep up the atmospheric seeing is going to be so bad no amount of mirror cooling will improve things. Here in SE Texas we normally have pretty good seeing right after sunset. Great time for planets! However, once the temps start to tank the seeing can be pretty bad until around midnight or so when the atmosphere finally starts to settle down.
I run my fans mostly for dew control. I don't see any visual improvement once seeing settles down.
  • sheath likes this
#16 Jon Isaacs
Posted 05 December 2024 - 07:22 PM
If the temperatures are be slow freezing and your scope is at room temperature, it may never cool down adequately.
My conditions are very mild, I still allow at least an hour and it takes more. But I'm expecting a stable atmosphere and a scope that's providing it's best at high my magnifications.
  • Sebastian_Sajaroff and sheath like this
#17 Napp
Napp
  • Loc: Northeast Florida, USA
Posted 05 December 2024 - 07:23 PM
As Tony pointed out, there is no such thing as crossing the dew point.  The dew point at any given time is the lowest that air temperature can drop to.  If the dew point continues to drop then temperature can drop.  If temperature equals the dew point condensation starts in the form of dew, fog or clouds.
  • sheath likes this
#18 Tony Flanders
Tony Flanders
Posted 05 December 2024 - 07:57 PM
As Tony pointed out, there is no such thing as crossing the dew point.  The dew point at any given time is the lowest that air temperature can drop to.  If the dew point continues to drop then temperature can drop.  If temperature equals the dew point condensation starts in the form of dew, for or clouds.
It's a bit more complicated than that. Dew generally starts to form when the air temperature is well above the dew point. That's because radiational cooling makes surfaces cooler than the air on a clear night. Moreover, the dew point down near the ground is often higher than the dew point at chest height, where it's officially measured.
But the underlying statement is true. As soon as the air temperature reaches the dew point, water condenses into some liquid or solid form -- either a film on a surface or droplets in the air, a.k.a. fog. The process generates a huge amount of heat, just as its reverse (evaporation) absorbs a huge amount of heat. So the air temperature never falls below the dew point.
It's possible to cool air slightly below the dew point in a laboratory setting, in which case the air becomes supersaturated with water. This can also happen in the upper atmosphere, where there's a shortage of condensation nuclei. But it never happens near the ground in everyday life.
  • Napp and sheath like this
#19 Mike Q
Mike Q
  • Loc: Monnett Ohio
Posted 05 December 2024 - 08:24 PM
Your normal condition are what most of us can only dream about
  • Jon Isaacs, Sebastian_Sajaroff and sheath like this
#20 Jon Isaacs
Posted 06 December 2024 - 10:26 AM
I agree.
Rob lives in White Rock, British Columbia and is wondering about cool down as the temperatures are dropping below freezing.  In San Diego where I observe with my 10 inch Dob, there have been 7 days in the past 160 years when the temperature was freezing or below. The average winter low is 50 degrees, the average winter high is 66 degrees.
But I believe the value of my experience for someone like Rob is that even in such a mild climate, the time it takes for my 10 inch Dob with dual fans to cool down for optimal performance is more than an hour.  If it is freezing outside, going from indoors to outdoors, that is going to take quite a bit longer.
Of course, optimal performance is the primary concern under optimal conditions. Other's, like Tony and yourself, have more practical concerns, will the telescope freeze over?
Every climate has it's advantages and disadvantages.. If I were an ice fishing enthusiast, I would be one frustrated dude.
  • RobVG and sheath like this
#21 Mike Q
Mike Q
  • Loc: Monnett Ohio
Posted 06 December 2024 - 10:40 AM
I agree.
Yes ...the telescope will at some point be frozen, been there done that.
  • sheath likes this
#22 edsmx5
edsmx5
  • Loc: Lower Pottsgrove, Pa. Bortle 5+
Posted 06 December 2024 - 10:41 AM
I agree.
If you start ice fishing in San diego, or in the high desert, we're all in trouble
  • Jon Isaacs and sheath like this
#23 Jon Isaacs
Posted 06 December 2024 - 10:50 AM
 Probably only me..
"Jon has finally gone off the deep end. We knew it was coming, the only question was "when'".  :lol:
jon
  • edsmx5 and sheath like this
#24 Mike Q
Mike Q
  • Loc: Monnett Ohio
Posted 06 December 2024 - 11:35 AM
If Jon goes ice fishing i will be there to watch, with a camera
  • Jon Isaacs likes this
#25 vtornado
vtornado
  • Loc: Kane County Illinois
Posted 06 December 2024 - 02:11 PM
12 inch dob takes roughly 2 hours to cool for me with a 20 degree temp delta.  I store the dob in my garage, but my garage is insulated and attached to the house on two sides.  Winter temperatures can be 20 degrees warmer in the garage than outside.
Maybe someday I will erect a garden shed, that should stay much closer to ambient.
Also some nights with a clear sky in the winter temps can fall 10 degrees per hour and the mirror never keeps up.  Counter to that seeing is probably bad anyways with that kind of temperature delta.
I suppose the same thing can happen if you drive to a dark site in the winter and want heat in your car.  grin.gif.   Maybe you can swaddle the tube with blankets???
This is more important for high power than low.
Edited by vtornado, 06 December 2024 - 02:17 PM.
  • Jon Isaacs and izar187 like this
