I pulled out the Starizona .65 reducer and put it on my ASI183 to see what it might do with the Rosette nebula. I have only used it one time so far. Rosette is not a very bright object so I figured the reducer might help to get a good image in a single night. I was able to get 147 files x 120s. I put the reducer on my Esprit 100. It fits inside the tube so it does not create a long image train hanging off the back. With the reducer the Esprit100 runs at f/3.6 and my image scale is around 1.4. I will try again and next time I will center the shot I think I can get most if not all of it in the frame. The stars are a little eggy around the edges but you don't really notice unless you closeup. I separated the stars out to process the nebula and did not run blurx on the stars which I should have it will make them look much better. I will also get more files.
