Suction cups work on ground surfaces, but I generally only use those to pick up one side of a blank so that I can get a block under it to clean, etc. Note the load limit, the inexpensive ones are ~100-125 lbs.
For up to ~22""-24" blanks, I can slide them off the machine and carry them because they are 50 lbs or less. For ~24"-36" blanks, I typically slide those off of my medium-sized machine (up to 36") and onto a rolling test stand that is the same height as the turntable.
I have adjustable metal lifting fixtures with three arms for ~28" to 45" mirrors that are less than 3" thick.
For 36" and larger mirrors, I use lifting fixtures where possible, or I slide straps under them to lift with a Sky Hook or rolling gantry crane when the Sky Hook isn't capable of the lift.
TOT is the way.
