Orion XT10g lid is loose
9 replies to this topic
#1 DarthMuffin
DarthMuffin
Posted 06 December 2024 - 09:49 PM
Hello all!  I have a new-to-me Orion XT10g.  The lid (dust cap?) is really loose, like it just rattles around and falls off.  Any idea what I'm missing here?  My first guess is a rubber band or o-ring, second guess is the plastic tabs are just fatigued and worn out.  Nothing looks broken.  Pic attached.
Edited by DarthMuffin, 06 December 2024 - 09:50 PM.
#2 mrowlands
mrowlands
  • Loc: WI
Posted 06 December 2024 - 10:35 PM
The lids on my GSO dobs fit snugly, but I've used self-adhesive felt pads for other lids/caps.  You can find a variety of sizes and thicknesses.
https://www.acehardw...re-pads/5021985
Mike R.
  • sevenofnine and Steve Cox like this
#3 SoCalPaul
SoCalPaul
  • Loc: SoCal
Posted 06 December 2024 - 10:51 PM
In case it needs to be replaced, I've often used shower caps for my closed-tube Dobs, like this: https://a.co/d/6QolZlw
Clear skies,
Paul
  • DarthMuffin likes this
#4 Bill Weir
Bill Weir
  • Loc: Metchosin (Victoria), Canada
Posted 06 December 2024 - 11:00 PM
Velcro is your friend in this situation. With my 1999 6” the tight fit is long gone. In two spots I have some of the felty bits attached to the tube then I have strips of the hooks glued at one of their ends to the outside of the cap so that the other end can reach to the felt. Easy peasy.
Bill
Edited by Bill Weir, 06 December 2024 - 11:01 PM.
#5 emflocater
emflocater
  • Loc: Clarkson, N.Y.
Posted 06 December 2024 - 11:08 PM
Have tried to gently bend all  the largest tabs toward the outside and see if it will fit more snug after?
Cheers
Don
#6 wrvond
wrvond
  • Loc: Leon, West Virginia
Posted 07 December 2024 - 12:04 AM
Nothing missing. My old XT10g and current XT12i did the same thing. A small strip of self adhesive Velcro on the edge of the lids snugged them up nicely.
  • CowTipton likes this
#7 cuzimthedad
cuzimthedad
    Just Be Cuz
  • Loc: Nampa, ID
Posted 07 December 2024 - 02:38 PM
Welcome to Cloudy Nights Darth!
#8 kfiscus
kfiscus
  • Loc: Albert Lea, MN, USA
Posted 09 December 2024 - 10:19 PM
The loose fit is a common problem.  Here's how I fixed my dust caps on two 12" GSO scopes.
I used my heat gun on its low setting and heated several of the tabs judiciously and one at a time.  I held each tab in needle-nose pliers and pointed the heated air at the tab until the plastic just began to soften.  I very gently bent the tabs outward about 1/32".  I only had to do a few of the tabs spaced around the perimeter.
Edited by kfiscus, 10 December 2024 - 07:17 PM.
  • emflocater and wrvond like this
#9 DarthMuffin
DarthMuffin
Posted 12 December 2024 - 10:58 PM
Cheers
Don
I just did.  Heated each up with my heat gun, bent them out about 1/8th inch (with a glove on) and held until they cooled.  Fits perfectly now, thanks.
  • emflocater, kfiscus and wrvond like this
#10 Kuba_81
Kuba_81
  • Loc: Poland
Posted 13 December 2024 - 03:05 AM
my lids on GSOs are tight inside the house, but loosen up outside when it's cold.
