Hi All,
Thank you each and every one of you for your VERY HELPFUL posts on my thread . . .
Now it is time for some deeper insight: I want to know more about the diameter as a function of length along the Axis of my Refractor of the light cone.
Say, I fully illuminate the Refractor with a lighted screen that fully illuminates the light cone and not just the Moon's Half Degree or Sun's Half degree.
If I call the "Thin Lens Approximation" for my 100mm x 900mm, F/9 lens Z = 0, what is the diameter of the f/9 light cone as it propagates down my Refractor from Z = 0mm to Z = 850 to 900mm to 950mm. I know that for much of the distance (Z < 850mm), the light cone can be modelled by a tri-angular cone such as (aka triplemon) shows in his drawing, but as the light cone gets near the focal plane, the diameter can no longer be modeled by the triangle that converges to a point at Z = 900mm (focal plane "image spreading"), but rather widens out as a de-focused "anti-cone" as the light cone approaches the focal plane spreading that has been discussed already or hinted at by the above. I am aware of vignetting issues . . . but would like a deeper understanding . . .
Anybody willing to explore this topic deeper with me ?
Best,
Ed
This is a good question. Important stuff if you want to calculate baffles.
The taper of the light cone is different for different sizes of field at the image plane, and different again for different focal lengths. You simply need to determine how much the cone tapers for a given length of the optical path.
Consider the following example:
Clear aperture = A = 100mm
Image size = S = 20mm (you get to choose this based of eyepiece field stop, camera size, personal preferences, etc)
Focal length of scope = Fl
In all cases the light cone tapers a total over the length of the cone, aperture minus the image size. (A-S).
For the scope in the example of 1000mm focal length, the light cone tapers 80mm over 1000mm or 80/1000= .08mm/1mm. Rate of taper = (A-S)/FL
To determine the size of the cone at any position along the length of the scope, simply multiple the distance from the focal plane by the rate of change and add that to the image size.
Size of the light cone at a distance d from the focal plane is S + d(rate of taper) = 20mm + d(.08mm). At 100mm distance this would be 20+8=28mm. Size of the light cone 200mm from the image plane = 20mm + (200 x .08) = 20 + 16 =36mm
Working from the other direction, the size of the light cone from the clear aperture would be A - d(rate of taper).
So in the example, the light come at 300mm would be 100mm - 300(.08mm) = 100-24 = 76mm
To summarize, Size of light cone is determined as Aperture minus taper or image size plus the taper.
Unfortunately, I can easily do the arithmetic but I don't know the industry standards for the symbols.
hope this makes sense,
dan
Edited by dan_h, 09 December 2024 - 02:05 PM.
