I did upgrade to 2.2.1, and it does seem to do what its supposed to, but ive noticed something a lil odd , especially when using mosaic mode. This is not a complaint, but simply an observation.
Im not sure if its memory (4gb) or just plain processing power that is causing it , but the little thing is now using a LOT more processing in mosaic mode (rotating/slewing/platesolving etc.) but the unit wasnt originally built with this in mind....also, i do believe the actual processing is done on the unit, not the app, so tablet memory shouldnt even come into play at all if thats the case
Basically, what ive noticed is that just before each move, i seem to get 2/3 dropped frames almost every time, and once the new area shows up on screen, its immediately followed by a much lower reject rate until the next move
even using just the restack feature is SLOW, averaging around 6/7 sec per frame to rotate/stack.
Im wondering, are half my subs rejected due to "star trails"? or processing power?
Ill be curious to see how the s30 fares in that regard, as it was actually built with this in mind
