Hi all, hoping to post some more around here and I’m looking to get some thoughts (and prayers) regarding this silly project I’ve been tinkering on. Yes, I’m afraid you read the title right, I will be attempting astrophotography at f/0.89, although mainly I plan to use this for EAA at live events and meetups.
My set up is based around the use of a 0.64X speed booster made by metabones for a specific pocket cinema camera, I chose this version of this model because it’s optimized for a much thinner sensor stack than what’s in most other micro 4/3 cameras, and I thought it fitting considering there’s only one window/filter above our astro cameras. This optic resides in the flange distance between a DSLR lens mount and mirrorless lens mount, and compresses a full frame image circle down to a Micro-4/3 sensor sized image circle. I also already have the longest focal length full frame f/1.4 DSLR lens, the Sigma 105mm f/1.4 Art. Combining these two give me an approximately 9.5° square field of view when paired with the 533MC sensor for example, at a blistering f/0.89. This is six times faster than a RASA! Now, realistically, it would be more at home in use with my 400mm f/2.8 for EAA and live stacking for an audience (~250mm f/1.7 equivalent exposure), but I will be using it at f/0.89 if only for the heck of it.
Getting this to work with an astro camera isn’t straightforward, as the adapter protrudes towards the sensor a good amount, and you need to actually remove the plate that holds the window above the sensor in place, but keep the window. That’s how tight the margins are! The window is required to correct for spherical aberrations introduced in its absence. When the window is in place and the speedbooster is extended to its fullest, the correction seems optimal and the image looks sharp. This window changes with the camera used, but at least for the 533 I can confirm a 31mm unmounted filter drops in to cover the gasket and will act as the only place in this optical train with enough physical space to fit any filter.
Anyways, the real question I have today is any suggestions for filters I can use, particularly as this EAA will likely be done under heavy light pollution. Obviously a proper narrowband filter would be out of the question due to bandpass shift, and I fear that any old light pollution filter with its bandpass notches would suffer the same fate. I do own, and, thanks to working at an astronomy/telescope shop, have access to lots of filters optimized for high speed imaging. But even those are only optimized for f/2. So what do you all think? Will a regular old cheap UHC style filter be ‘sloppy’ enough in its bandpass to allow full use of the f/0.89 aperture? I know Celestron has light pollution filters with notches optimized for RASAs, but they’re hard to come by. Maybe an IDAS DTD? Love to hear your thoughts, and I’ll keep you all updated on the project!
