Taking flats with light panel
#1
Posted 08 December 2024 - 08:01 AM
#2
Posted 08 December 2024 - 08:09 AM
I used a light panel to shoot my flats for my 8" SCT and it worked fine. I had to use several t-shirts in front of it to soften the light enough to work. For my 100MM refractor I use an Ipad light screen and it works really good also. The Ipad fits right over the opening and then I can get the histogram right on the money.
#3
Posted 08 December 2024 - 08:24 AM
#4
Posted 08 December 2024 - 08:32 AM
The instructions you read meant don’t rotate the camera relative to the optics. It’s ok and likely necessary to rotate the mounted rig to point at the zenith to balance the flat panel. Or remove the rig from the mount and put it on a table and prop up the flat panel in front of the ota.
Great! Thank you!
#5
Posted 08 December 2024 - 09:09 AM
The iPad sounds like a nice solution - how do you get it to display a light screen?
#6
Posted 08 December 2024 - 11:15 AM
It is an Ipad app available in the app store for free. It is just an adjustable light panel that uses the entire screen for the panel.
#7
Posted 08 December 2024 - 06:53 PM
https://darkdragonsa...pad-flat-panel/
#8
Posted 08 December 2024 - 07:59 PM
Or create white image and upload it to your iCloud drive, then just play with display brightness.
#9
Posted 09 December 2024 - 11:19 AM
