Antlia Triband you mean? almost said the Antlia Tribunal
no, do not use the Askar D2 filter for this
if you're planning on getting H-a from the area, then yes, the D1 is your best bet (good luck with that though, I don't think the H-a is very bright)
if you're planning on getting simple full color broadband images, then use a normal UV-IR cut - that might sound strange to you, but, you and other beginners must understand that light pollution filters do nothing at all to help you get better signal for -broadband- targets (galaxies, dark and reflection nebulae, I mean), it's just cutting out light from what is already present, filtering out the so-called "light pollution" wavelengths, it just doesn't do magic; those "light pollution wavelengths" include actual signal from the DSO, so that's why I say it doesn't help.
my logic tells me they were a lot more useful for broadband targets when we didn't have so many LED lights, because, LP filters are meant to filter out the wavelengths of those old lamps (like sodium) that used to be more prevalent; they really don't help now, except if you want better signal off of emission/planetary nebulae which are stronger in some special wavelengths that LP filters usually pass
my 2 cents - just my understanding of it
CS,
John
Edited by John Berger, 08 December 2024 - 07:44 PM.
