Vintage Celestron-8 Knob Problem
Celestron Classic
4 replies to this topic
#1 HighwayRob
HighwayRob
Posted 11 December 2024 - 04:37 PM
Team,
The little knob in the picture turns, but does not rotate the telescope base. It use to work, then stopped. If I manually rotate the base, it spins the knob, but not the other way around. I guess after 45+ years sitting in a Florida garage it may just of deteriorated or I just busted it.   Can I open this thing up?  Can I fix it easily? Can I order a new knob from Celestron?
Thank you in advance for any ideas!
Rob
Edited by HighwayRob, 11 December 2024 - 04:37 PM.
#2 jurdea
jurdea
  • Loc: Centennial, CO
Posted 11 December 2024 - 04:46 PM
Is the knob anchored to the shaft?  Should be an allen screw on the knob that needs to be checked for tightness.
  • ShaulaB and Daveatvt01 like this
#3 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 11 December 2024 - 07:57 PM
  The knob can be simply spinning on the shaft because the set screw is loose like it has been stated. . Also the shaft of the knob is in an eccentric bushing. There is set screw that holds it in place. You can loosen the screw and then rotate the bushing so the gear on the end of the shaft will engage the large gear it drives.
                          - Dave
  • CharLakeAstro likes this
#4 HighwayRob
HighwayRob
Posted 18 December 2024 - 01:48 PM
Simply a loose set screw.  Never thought to look. Problem solved!
Thank you!
  • Josephus Miller likes this
#5 Orion928
Orion928
  • Loc: Sistersville, WV
Posted 06 January 2025 - 12:17 PM
I am trying to make some modifications to my old orange C8.  What size allen wrenches do I need to remove the RA and Dec knobs?  I've tried both metric and SAE but everything seems to be either too big or too small.
Thanks, Greg
Also tagged with one or more of these keywords: Celestron, Classic
