ClintonVA,
You bought this scope used, so are you sure it's in collimation? No one has mentioned this, and I'm not the best person to write on the subject, being that I have never owned an SCT in my life, but I am a little familiar with the process from friends in my astronomy club. I am very familiar with newtonian reflector collimation, however, and can guarantee you that no eyepiece can make a mirror-ed telescope out of collimation work well. If your scope needs collimation, however, it's akin to a guitar needing tuning. Doesn't mean the guitar is junk, just that it needs adjustment and that's all. Your C8 may be putting up rotten renditions of things because it's not collimated.
Again, I'm the last person to give you good advice on this subject, since I've never owned an SCT, but I can tell you that when I collimate my C130SLT telescope, that little guy throws up the best images a 5.1" mirror might throw into your eyeball. Everyone's commented before on how sharp and nice my stars are, and it does a very, very nice job, but that's because I've made sure the mirrors work correctly, and, although the process is a little different with a standard newtonian compared to an SCT, correct collimation makes a lot of difference in what your scope will show through any eyepiece. I'm sure there are dozens of YouTube videos and libraries worth of commentary available from googling good ole Cloudnights.com on the subject, so help is at hand, but you might need to at least check your collimation and make sure things appear "correct". A star test on Polaris comes to mind as a simple test, but whatever you decide or settle on as your best method, make sure your collimation is good before giving up on the scope. A great, classical guitar formerly owned by Andrés Segovia might get out of tune, but could still be worth a few tens of thousands of dollars, and so it is with a C8 out of collimation. It might throw up some bad images with the mirrors out of alignment, but get them aligned and it is likely to produce a much better image.
Good luck
Edited by CollinofAlabama, 19 December 2024 - 02:26 PM.
