Takahashi TOE 3.3mm vs Vixen HR 3.4mm vs Nagler 3.5mm in binoviewing
8 replies to this topic
#1 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 23 December 2024 - 10:59 AM
I will compare these intertesting eyepeices in bino mode, and will post my findings here both for physical and optical comparation.
While APO SS binoviewer does not suffer from false colours, not from spherical error, like my Baader Mark V binoviewer does, its will be great to do that comparation in binoviewer mode using APO bino.
Will also try using Mark V bino + Baader GPC.
More to be posted later on....
Kind regards,
Denis
  • manolis likes this
#2 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 23 December 2024 - 11:00 AM
...more view at epcs...
#3 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 23 December 2024 - 11:01 AM
...and bottom line comparation when eyeguars are removed.
I will be using all eyepeices without rubber eyeguards for more comfort.
  • Sergey Stern and Lookitup like this
#4 Kutno
Kutno
Posted 23 December 2024 - 12:29 PM
I look forward to reading your report.
Apart from your signature Apo, will you be comparing them in another scope?
#5 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 23 December 2024 - 01:01 PM
I will be primarly using/testing them in my LZOS 180mm f/7 APO, but im on waiting list to buy also Takahashi 100mm DZ Fluorite doublet, but have no idea when I will get it.....
But LZOS 180mm APO will be superb for testing.
  • manolis, cahanc, Kutno and 2 others like this
#6 manolis
manolis
  • Loc: Greece
Posted 26 December 2024 - 02:57 AM
#7 zdravko
zdravko
  • Loc: Maribor,Slovenija
Posted 07 February 2025 - 06:04 AM
Denis How did the test go?  I hope you managed to test as there have been quite a few clear nights with pretty good seeing since then?
#8 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 07 February 2025 - 07:45 AM
Hello,
Vixen HR epcs are bit more comfortable (eyeguards removed on both), have less scatter, and are a bit sharper showing bit more easily more details.
  • mikeDnight likes this
#9 Highburymark
Highburymark
Posted 08 February 2025 - 09:10 AM
The HR does feel slightly more comfortable (I’m referring to single eyepiece viewing here), but I wonder whether that is because the AFOV is much narrower, so you need to get closer to the TOE to see the field stop.
