RC telescope collimation or reflection or other issues?
Optics Equipment Collimation Classic Catadioptric
7 replies to this topic
#1 lihao19943
lihao19943
Posted 30 December 2024 - 10:13 AM
I have an RC18 telescope, and recently during the imaging process, some moderately bright stars at various off-axis locations have a bright semicircular halo toward the center of the light axis, and a slightly dimmer halo in the other direction of the axis. Is this a collimation problem of the optical axis or is there some kind of reflection in the telescope system?
It is worth noting that this halo is only clearly resolved when FWHM<2".
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 30 December 2024 - 10:39 AM
Alluna RC18?
What a scope!
So there shouldn't be internal reflections.
Is it shrouded?
What components are there in optical path?
Edited by Tapio, 30 December 2024 - 10:39 AM.
  • lihao19943 likes this
#3 rzep8
rzep8
  • Loc: Flemington, NJ
Posted 30 December 2024 - 11:20 AM
I don't think this is a collimation issue as the stars do not appear to be oval or astigmatic. Are you using a filter? Possible reflections off the filter might be my guess.
#4 lihao19943
lihao19943
Posted 30 December 2024 - 01:14 PM
Alluna RC18?
What a scope!
Is it shrouded?
Yes, in the optical path of the Alluna RC18, there are a CAA, an extension adapter, an OAG, a filter wheel, filters, and a camera.
#5 lihao19943
lihao19943
Posted 30 December 2024 - 01:24 PM
Viking
Yes,I using the Chroma filter.
When installing the filter, make sure the bottom of the text on the filter faces the camera.
Because I am using the filter wheel of the Morivian C3-61000EC-pro camera, only three screws with rubber retaining rings are used to fix the filter during installation. This results in a part of the screws being "protruding" inside the filter. I don't know if this will cause such artifacts to appear. Should I replace it with a circular retaining ring like the ZWO filter wheel to fix the filter?
#6 lihao19943
lihao19943
Posted 31 December 2024 - 07:07 AM
Tonight I'm going to flip the filter over and test it to see if it fixes the problem.
#7 rzep8
rzep8
Posted 01 January 2025 - 06:21 PM
Viking
Oooh.. that much I can't answer. My only thought on that is taking the camera off and looking down the connection to the filters. Possibly shine a light down there and see if anything reflects back.
#8 lihao19943
lihao19943
Posted 02 January 2025 - 12:43 AM
I took the filter off and ran some tests. I found that the halo problem still existed. I put it into virtual focus to make the problem more obvious. From the image, it seems that there are two strange diffraction rings, and they are oriented towards the center of the optical axis at all four corners of the focal plane.
Therefore, I judge whether this is a problem caused by some protruding structure or burr in the optical path or uneven pressure ring of the main mirror and other defects?
Also tagged with one or more of these keywords: Optics, Equipment, Collimation, Classic, Catadioptric
