Optimal type of diagonal for Japan classic F15 refractor ?
9 replies to this topic
#1 rmorein
rmorein
Posted 04 January 2025 - 02:43 AM
Somewhere, I caught a remark that the Zeiss Telementor reaches optimal performance with a prism type star diagonal, because the objective is designed to compensate for the spherical aberration of the prism.
Conversely, if an objective is not designed to compensate, it would perform better with a mirror-type diagonal. Which is apt to be the case for classic Japanese refractors ?
#2 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 04 January 2025 - 03:15 AM
The Telementor objective is not designed to compensate for the spherical aberration of a prism. The spherical aberration introduced by a small prism at f/13.3 is very small and can safely be completely ignored. The same is true of the classic Japanese refractors, which are often f/15, or even longer, and rarely shorter than f/10.
Clear skies!
Thomas, Denmark
  • deSitter likes this
#3 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 04 January 2025 - 11:08 AM
 A prism doesn't add spherical if made correctly but  it adds chromatic aberration because of the angle of the light entering it.  With slow f-ratio scope like  a F/15 refractor it adds little  chromatic aberration to the image but when the F-ratio gets faster it does add chromatic aberration. and no  it does not  compensate for the chromatic aberration of the objective . If it did it would have been done 100 years ago and commonly known and practiced  If you want the best color correction use a mirrored diagonal.
  Here is  an example of  the ray tracing  of 10" f/8 Newtonian were the secondary is a mirror diagonal and one were it is a prism. The black circle is the size of Airy disk.  With the mirror diagonal the image is perfectly achromatic, and has no spherical aberration,  but  with the prism you can see the color blur with light now falling outside the Airy disk.
                   - Dave
  • deSitter and jragsdale like this
#4 Astrojensen
Astrojensen
Posted 04 January 2025 - 01:29 PM
Yes, it does. See https://www.cloudyni...the focal ratio.
Posts #5, 8, 10, specifically.
See also https://www.telescop...s_optics.htm#be
Clear skies!
Thomas, Denmark
#5 jkmccarthy
jkmccarthy
  • Loc: Los Angeles, California U.S.A.
Posted 08 January 2025 - 03:11 PM
This thread recalls to my mind Wolfgang Rohr's optical performance measurements and report on the Vixen ED115S (D=115mm, F=890mm, f/7.74) refractor, in which he describes how including a prism diagonal (there being 50mm of optical path length in the diagonal he used) actually improves the optical performance of the OTA (most notably in the violet and red extremes) to a near APO level., which I found quite interesting.
See:  http://r2.astro-fore...t-ein-apo-phnoa
Specifically, compare the measured performance Mit Glasweg (with glass path through the prism diagonal) to the measured performance Ohne Glasweg (without glass path) to assess the improvement in this case.
Clear Skies,
        -- Jim
#6 photiost
photiost
  • Loc: Montreal, Canada
Posted 08 January 2025 - 06:41 PM
I have always believed that slow refractors will perform better with prism diagonals, anything faster than say f/10 will perform better with a mirror diagonal.
In any case some of our clubs "older members" insist on observing straight through with no diagonals.
  • jragsdale likes this
#7 jragsdale
jragsdale
  • Loc: Idaho
Posted 08 January 2025 - 07:31 PM
This is the way.
  • photiost and Steve Allison like this
#8 photiost
photiost
Posted 08 January 2025 - 08:44 PM
This is the way.
#9 k5apl
k5apl
  • Loc: Arkansas
Posted 08 January 2025 - 10:15 PM
I used the inexpensive Celestron 1.25 inch prism diagonal wth my f13 4 inch achro refractor because it had good images and it was
collimatible.
Wes
#10 jkmccarthy
jkmccarthy
Posted 09 January 2025 - 07:57 AM
This is the way.
Agreed ... at least until the zenith angle decreases to less than 30-degrees or so !!
  • photiost likes this
