Astrometry reduction program to asteroid detection
7 replies to this topic
#1 brebisson
brebisson
Posted 05 January 2025 - 02:37 AM
Hello,
Our club is trying to get into asteroid measurement reporting...
What SW do you guys use to do the measurement part (find position of moving object in the image)?
Cyrille
#2 david_od
david_od
  • Loc: Chile
Posted 05 January 2025 - 05:32 AM
Some useful programs are Tycho Tracker, MPO Canopus, and ASTAP.
If you want something simple to start, and assuming you are observing relatively bright asteroids, Siril can help you as well if you want to do it more manually.
Edited by david_od, 05 January 2025 - 05:45 AM.
  • Al Paslow likes this
#3 Ed Wiley
Ed Wiley
  • Loc: Texas, USA
Posted 06 January 2025 - 11:38 PM
Tycho is my strong recommendation.
Ed
  • SeymoreStars likes this
#4 555aaa
555aaa
    Vendor (Xerxes Scientific)
  • Loc: Ellensburg, WA, USA
Posted 13 January 2025 - 04:30 PM
Astrometrica and Tycho. I think Astrometrica is the simplest to use but has a very finicky plate solver (but accurate).
Edited by 555aaa, 13 January 2025 - 04:32 PM.
#5 brebisson
brebisson
Posted 14 January 2025 - 02:48 AM
Hello,
Thanks, for your help.
I was finally able to use astrometrica...
As you said, it is finicky, but it works and is easy to use...
This is not helped by the fact that I shoot with a scope with a 4800mm FL... None of the SW are designed to work with stars that are 20 or 30 pixel large...
Since I was not able to test Tycho with my dataset, I discarded it from my list...
Cyrille
#6 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 14 January 2025 - 02:53 AM
Cyrille
Why is that?
#7 555aaa
555aaa
Posted 14 January 2025 - 03:33 PM
Hello,
Cyrille
I am using Astrometrica at 4000mm focal length and it works well but you should use binning if your stars are 30 pixels across. It works better than if you are at say 600mm and very wide field like the RASA, it really struggles on having so many stars.
#8 brebisson
brebisson
Posted 14 January 2025 - 03:42 PM
Hello,
Ho, I am binning 4*4! This reduces the large stars to around 15 pixels...
Cyrille
