85mm Sigma ART and the Witch Nebula - The Ultimate Mosaic Lens
#26
Posted 21 March 2025 - 09:49 AM
Yes, I agree that coma and other aberrations are always present. I also agree that what counts in the end is whether one is happy with the overall aesthetic of an image and not the details of what is going on in the corners. For the particular copy I was using what disturbed me more was a strong asymmetry in the coma on a canon 800d. The lens has now been returned and I await a replacement.
I’ll report back if there is anything interesting to say - most likely the new copy will show imperfections as well, at which point I’ll stop fussing and get on with some imaging!
I’ve actually captured five hours of M81 which looks good considering it is under B4 skies - not as good as yours though.
Thanks again for your advice.
CS, Des
#27
Posted 23 March 2025 - 08:12 AM
Thanks, Daniel.
CS, Des
Awesome. Look forward to seeing more of your images.
#28
Posted 22 May 2025 - 03:27 PM
So dumb question but I thought all of the ART lenses are focus-by-wire. Meaning they need power to focus because it's the internal focus motors that are translating the motion of the focus ring to actual movement of the lens elements (no physical helicoid). Is that not the case for certain lenses or do you have some way of providing power to the lens even though it's attached to a ZWO camera?
#29
Posted 22 May 2025 - 04:26 PM
All my canon mount ART lenses can be manually focused.
Edited by Daniel Dance, 23 May 2025 - 05:28 AM.
#30
Posted 22 May 2025 - 07:53 PM
#31
Posted 22 May 2025 - 08:50 PM
Sure Sony FE lenses are out of the question - the flange distance of an FE mount lens is too short to make an adapter possible with the inherent backfocus that's built in to ZWO cameras (minimum 12.5mm if I remember right). I'm a little surprised that they are still making some lenses that aren't focus by wire. Are these older ART lenses?
#32
Posted 23 May 2025 - 05:27 AM
I dont know of a single ART lens that is focus by wire. I own about 6 of them - 4 purchased in past year and they are all mechanical direct drive focus rings.
Which ART lens do you think is focus by wire?
#33
Posted 23 May 2025 - 01:00 PM
I've only had Sony FE mount ones- including 24-70 DG DN II and 105/2.8 DG DN. Fairly sure both are focus by wire
#34
Posted 23 May 2025 - 05:32 PM
I have three of them for Sony
135mm DG f1.8 focuses with a helicoid. It does not have an aperture ring. I believe it was adapted from a DSLR and is no longer in production. Fabulous lens with amazing bokeh
85mm DG DN f1.4 and 35mm DG DN f1.4. Both are focus AND aperture by wire. They do both have an aperture ring but it does not operate off camera and it closes all the way down when the camera is turned off.
Edited by norcalryder, 23 May 2025 - 05:33 PM.
- msalganik likes this
#35
Posted 24 May 2025 - 06:35 PM
Incredible! Great contrast and colors
You must have some really dark skies
Edited by Alnitak2009, 24 May 2025 - 06:37 PM.
#36
Posted 27 May 2025 - 07:05 AM
Not so much. This was captured in Bortle 4-5 skies in NJ.
