My school has recently purchased a SA grating for its observatory and I plan on using it with a planetary camera to capture the spectra of stars. I have watched this video explaining how to use Rspec: https://www.youtube....h?v=6MrFuNGLsUE
It is explained that you should start with an A-star to calibrate using the Balmer lines. The star that was used as an example was Vega. I live in the Northern Hemisphere and as of right now Vega is just more than 20 degrees above the horizon once it gets dark enough to start shooting (or what I think is dark enough to start shooting).
My questions are:
Can I still capture Vega to calibrate?
If I can't capture Vega either because it is too low above the horizon or it turns out that the view is blocked (unlikely), what other stars can I capture instead of it?
How do I determine the best settings to capture spectra?
Are there any other things I might want to know about before acquiring data?
