ZWO FF107 problem?
18 replies to this topic
#1 bullmav
bullmav
Posted 06 January 2025 - 02:33 PM
Hello folks,
I received my ff107 a few weeks ago and finally had an hour of roughly clear skies to do a test
I made a quick test shot with guiding of m42 to test the scope and also saw weird spikes.
Is this the a pinch optics issue? See a pictures below
Test shot is a single frame of 300seconds with a ZWO 2600mc and guidingscope and cam (zwo 290) on a EQ6R-PRO mount) roughly 0 degrees temp. outside.
I use the same camera with my Askar FRA400 and have no problems at all.@bullmav
Anyone any ideas?
Edited by bullmav, 06 January 2025 - 03:05 PM.
#2 Cliff Hipsher
Cliff Hipsher
  • Loc: Disputanta VA
Posted 06 January 2025 - 02:56 PM
I am not on X so I can't get to the pictures.  Try posting them here.
#3 John Miele
John Miele
  • Loc: North Alabama
Posted 06 January 2025 - 03:24 PM
Not sure if you saw my recent post here...
https://www.cloudyni...pinched-optics/
I am also seeing strange star shapes with my new FF107.They look similar but not identical to yours. I plan to try heater strips on the tube to see if that fixes it. My image was also taken on a cold night.
FWIW, I contacted ZWO tech support today and received a reply within a few hours. They recommend to also check that the tube rings were not snugged down too tightly. I will check into that as well.
cs...John
Edited by John Miele, 06 January 2025 - 03:25 PM.
#4 bullmav
bullmav
Posted 06 January 2025 - 03:49 PM
Hello John,
I did saw your post. Wierd stuff going on I would say.I also contacted ZWO today. Having terrible clear skies up here for weeks. Not a single star to catch also for the upcominng days so testing is a no go for now.
I will also try to loosen the tube rings and use my two new dew heat straps next time.
Wil report my rep[ly from zwo and outcome of test in this forum.
Regards
#5 John Miele
John Miele
Posted 06 January 2025 - 03:57 PM
It looks like I will get a clear and cold night tomorrow. My heater strips are supposed to arrive today. I will let you know how it goes!
cs...John
#6 bullmav
bullmav
Posted 07 January 2025 - 06:51 AM
Update:
I received the feedback from ZWO to check the tube rings. Make sure that they are not "over tightened".
I will do so and provide feedback to ZWO and post an update here @ the forum.
  • John Miele likes this
#7 bullmav
bullmav
Posted 07 January 2025 - 04:59 PM
John, are you using filters? Like a light pollution filter? If so in what way? Are you using a filter wheel or a filter drawer?
I did a test this evening and still had the same spikes with loose tubes and dew straps attached. Target was again m42 which was low near earth. Around 30” in the sky. At some point I tried Mars as a test and again had the spikes. Mars was more towards the 45 to 60” in the sky. Tried everything till the point that I removed my lightpolution filter and tried M42 again. At this point higher in the sky. Result, round stars… now i put the filter back in my zwo filter drawer and made a test shot and all was fine found round star… so how could this be the case because besides the fact that I removed the filter had it in a warm place and entered it back at some point nothing changed. Beside the fact that at this time Orion was higher in the sky and was pointing less towards a light polluted sky (street lights). Could streetlights be the bad guy in this case?? Could a filter be the bad guy… lacking time due to clouds I had to stop and was unable to test further. I hope to have some more clear skies in the upcoming days to test the configuration again and try to pinpoint the issue.
I”ll attaches photo’s asap.
Picture of spikes (after loosening tubes and adding dewband)
IMG 2936
Edited by bullmav, 08 January 2025 - 11:21 AM.
#8 John Miele
John Miele
Posted 07 January 2025 - 06:34 PM
I was using no filter, no reducer, nothing but the scope and my camera.
Looking at your star image again, it appears you may have something a little different going on than what my image shows. I think I am clearly in the realm of pinched optics. Your stars had more of  well defined bright diffraction looking spikes. It is a mystery to me. Tomorrow, I finally get a clear sky and can try the heater strips.
cs...John
Edited by John Miele, 07 January 2025 - 06:34 PM.
#9 John Miele
John Miele
Posted 11 January 2025 - 06:39 PM
Hi Bullmav,
Any news on your fix?
You did not leave a bhatinov mask on by any chance? Your 2nd image looks very much like a bhatinov focus pattern.
#10 bullmav
bullmav
Posted 12 January 2025 - 08:01 AM
Hi John,
I’m very confused. After removing the filter I had clear round stars. So I thought the problem was the filter. Putting back the filter gave me still round stars. So I’m very confused right now. Could be the fact that m42 was close near some streetlights that caused the spikes. No mask attached. I don’t have one. I’m using EAF’s to focus. Still no clear skies to retry my setup. Hopefully by the end of this week we are getting some clear skies again. I’ll report after I did another test.
Edited by bullmav, 12 January 2025 - 11:43 AM.
#11 John Miele
John Miele
Posted 12 January 2025 - 01:48 PM
Maybe it was very cold the first night and warmer on the other nights? Not really sure what caused it, but it sounds like you are in good shape now. Sadly, my sample still has issues...
#12 bullmav
bullmav
Posted 12 January 2025 - 02:12 PM
That was not the case because the same night, in de beginning, I still had the spikes. So i need another clear night to figure out the problem I have.
BTW, I also have a FRA400 with no problems at all so the cam is not the problem.
I'll update this post as soon as I have more info.
I attached 3 dewheaters just to make sure the ff107 is "warm". I'll check if this is the "solution".
#13 bullmav
bullmav
Posted 02 February 2025 - 08:57 AM
Hi John, how are you doing.
I saw you returned your FF107?
I contacted ZWO today also, i had a good open night yesterday (cold, aroun -8 degrees celsius) and again had star spikes. Even with 3 dew heatstraps attached.
I hope they will provide me with a new one also.
Light IC434 300.0s Bin1 gain100 20250201 230845  0.6C 0008
Light M42 300.0s Bin1 gain100 20250201 221837 0.5C 0009
Did you have to pay for the shipment to china?
regards Maikel
#14 John Miele
John Miele
Posted 03 February 2025 - 12:53 AM
My replacement scope is on the way. I don’t have the expected arrival date yet. They sent me a prepaid label to return the first one. But I only had to ship it to New York. Not china. They must have a US support center
#15 bullmav
bullmav
Posted 03 February 2025 - 07:40 AM
Hi John,
Thank you! I'm realy out in the blue. Yesterday started with an image session. Still spikes. in that same night switched targets and was able to image M42 10x 300sec without spikes... om totaly confused now.
I'll just wait on the reply from ZWO to check what they have to say.
#16 civis
civis
  • Loc: Mid-west
Posted 22 March 2025 - 03:16 PM
My new FF107 appears to have rather severe spherical aberrations, as per star test - in-focus nice symmetrical airy rings, out of focus fuzzy mess, barely any rings visible. Does it make sense to try exchange it? How high are my chances to get a good one?
#17 Cliff Halliwell
Cliff Halliwell
Posted 26 March 2025 - 07:36 PM
Hello folks,
Anyone any ideas?
I had pinched optics on my 107PHQ, which persisted despite additional heaters.  They manifested as somewhat triangular stars but no spikes, and across the full field.  Yours are quite asymmetric, on the right of your image.  My dealer and ZWO arranged to replace it.  The new OTA was fine.  You might use some of the available software to look at field flatness.  That might confirm that something is off-plane.
#18 bullmav
bullmav
Posted 05 April 2025 - 03:18 PM
Finally found the problem. I had two type of spikes.
One are solved with 3 dew heaters and the other problem (i was very stupid) was that a small tree branch was in the image creating a strange spike (like bathinov), I now use the gear without any problems at all. smile.gif
Good luck and clear nights folks
Edited by bullmav, 06 April 2025 - 12:25 AM.
#19 John Miele
John Miele
Posted 05 April 2025 - 06:41 PM
Great news Bullmav!
As you know, my first FF107 was riddled with spikes coming off my stars even with dew heaters. But my replacement unit is nearly perfect. I have only had the chance to use it a few times but I could not ask for better star shapes all over the field. Exactly what I wanted with the image scale right at 1 arc-sec/pixel. I am pleased with mine.
cs...John
