astroscan nubee
Beginner
3 replies to this topic
#1 seanmartin
seanmartin
Posted 06 January 2025 - 08:13 PM
hi
I hope I am in the right spot
I just got an astroscan telescope at the flea market and am having some trouble
I gently cleaned the front glass and the one eye piece that came with it( 28mm)
when I train it on and object of a distance of a couple hundred feet it will focus sharp
but when I tried to look at the moon it would not focus sharp, it would appear to start to focus but then as I would continue it got worse again
I did some googlin and see that there may be something going on with the big mirror positioning, relating to some foam backing breaking down
but I am not sure if this is a symptom or not
any sage advice and or direction would be greatly appreciated.
seanmartin
#2 ShaulaB
ShaulaB
  • Loc: Missouri
Posted 06 January 2025 - 08:21 PM
Is the eyepiece holder slipping down? Can you get it focused on the Moon, then it goes out of focus? That's a common problem that can be fixed.
The 28 mm Edmunds RKE eyepiece is one of my favorites. It is the opposite of the new-fangled "porthole in space" designs.
  • CharLakeAstro and starfinder123123 like this
#3 HagglePig420
HagglePig420
  • Loc: Lanoka Harbor, New Jersey
Posted 07 January 2025 - 02:33 AM
If it's an old Astroscan, it almost certainly needs to be collimated... or the foam that supports the primary needs to be replaced...
#4 seanmartin
seanmartin
Posted 12 January 2025 - 12:57 PM
Thanks for the reply
It did indeed need some work
I did some fishing around for info and found a good thread on breathing new life into the can
The eyepiece holder was firmed up with a piece of electrical tape applied vertically on the holder where it makes contact with the shaft (it would be nice to replace the rubber hose though).   any ideas?
I removed all the glass and cleaned them with some solution I use for cleaning my records and it worked great
The foam backing was in sad shape as was foretold
I got some thin packing material, the white closed cell stuff, and cut three concentric pieces starting at about an inch and a half and up to three and a half
instead of using one thicker piece. This would sit nicer in the curve of the can
As far as the snap ring installation I made a little holder out of a hacksaw blade. It basically holds the spring together so you can just get it where you want it and then release it. It made a nice holder when you have to reach down into the scope for the primary mirror
I tried it out on the moon and it focused nicely. I have since ordered a peep hole finder and a barlow x3 to see how that works
I think it will be a nice camping scope
  • mdowns likes this
Also tagged with one or more of these keywords: Beginner
