I bought what might have been the first Askar 203 in the U.S. back in September last year, and had it for about three weeks before sending it back to the distributor.
It appeared to have an optical issue which to me looked like spherical aberration. When looking at a star, a series of concentric rings radiated out from the Airy Disk.
As you focused the star to a fine point at high power the Airy Disk would shrink down to a smaller than typical size for the aperture and the rings would grow in size. Splitting a binary star less than 2" was impossible due to the interference of the ring pattern.
Looking at a planet, the 203 would not come to perfect focus. I could see a relatively sharp image superimposed over another less sharp image. It was a subtle almost ghost like effect, and clearly not correct.
Objects like M42 look spectacular, but resolving the Trapezium down to the E and F stars which the 185 does with ease, left the 203 struggling due to the ring pattern around each of the four main components.
The intra focal pattern looked okay, although you could just see what appeared to be a central zone. At the extra focal position, the zone was bright and grew in size as focus moved out before dispersing into the rest of the fainter rings.
The Askar 185 was along side during my viewing sessions and it easily outperformed the 203 in sharpness. The ability to see fine stars in M13 at low to mid power with the 185 is something the 203 should have been more than capable of, but the 185 was superior due to the lack of perfect focus in the 203.
The 203 is quite a beast compared to the 185. Much heavier feeling than the actual difference, with more front bias making it awkward to mount. A permanent mount in an observatory would be needed to get the most out of this size refractor.
Fit and finish of the 203 is excellent overall, and with the collapsible draw tube it's very compact for an 8" refractor. The 203 didn't appear to have any thermal issues with the lens as the optical aberration did not change regardless of temperatures.
I took some deep sky photos with it and they didn't look too bad compared to the view through the eyepiece (stars appeared slightly more bloated than the 185), but I bought the 203 more for visual use.
After contacting Askar with the issue they asked for photos of the intra and extra focal pattern, and they subsequently handled the return with help from the distributor very professionally.
I would say their customer service is top notch, especially in handling a scope of this size.
It's difficult to understand how a scope like this is not just tested photographically, but also visually as it's likely that a large percentage of buyers would use it for that purpose.
There is certainly a lot of potential for the 203 to be a great scope, and I'm sure once the issue gets sorted out the scope will get into regular production.
I'm guessing they are still working on issues with lens polishing that looks to be creating a central zone, but maybe some of the people here on CN might understand more about what I am describing optically.
Edited by ZX12, 11 January 2025 - 10:06 PM.
