I have an Orion XX12g and have recently modified the primary cell. I replaced the collimation springs with Belleville washers (thanks Starman1!), and while I had the mirror cell out, I replaced the cork pads with Nylon screwheads (I drilled and tapped the support points and threaded in 1/4" Nylon screws with 1/2" heads).
The new pads (screwheads) hold the mirror a little higher than the cork pads did, so now the mirror only rests on the nine supporting points in the middle 50% of the mirror's rear surface. Should I add support points farther out along the bottom edge, and if so, how many and in what locations?
The mirror is also supported/held along its circumference by three factory-supplied, Nylon-tipped, centering screws.
