Dark rings in stars - what SharpCap setting did I mess up?
10 replies to this topic
#1 MarMax
MarMax
  • Loc: SoCal
Posted 10 January 2025 - 11:41 PM
I must have changed a setting in SharpCap without knowing it. The PNG saved with adjustments does not have the dark rings but the FITS file does. This is a screen grab of the FITS file opened in Astro Pixel Processor.
IC 342 screen grab
This is with the 533MM and taken about a week ago. I just now got around to looking at the 32-bit FITS stack and was surprised to see the dark rings.
What setting did I mess up this time?
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 11 January 2025 - 01:50 AM
IMO looks like the pixels are saturated.  Need others to jump in.
#3 Clouzot
Clouzot
  • Loc: French Riviera
Posted 11 January 2025 - 03:16 AM
Apart from the Preprocessing / Mask overexposed pixels setting (which shouldn't apply to individual saved FITS anyway), or the odd bug in SC, I don't see anything. Does that happen with other software (Siril, ASTAP etc) when you open the same file?
#4 RodgerDodger008
RodgerDodger008
  • Loc: Perth, Australia
Posted 11 January 2025 - 03:47 AM
Never seen anything like that before, mismatched darks maybe, there are some stars of similar brightness without the artifacts which seems strange. If the saved as seen does not have this atrifact I would say it is software related maybe but that is a super wild guess. Open the same image in GIMP and see if the same artifacts show up.
#5 DirtyRod
DirtyRod
  • Loc: Arizona
Posted 11 January 2025 - 07:49 AM
I’ve seen it but only after a processing issue. What “adjustments” did you make?
#6 fullthrottle_man
fullthrottle_man
Posted 11 January 2025 - 08:38 AM
That picture looks like the results I get when I turn on the Hot Pixel Remover feature in SharpCap...
#7 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 11 January 2025 - 09:16 AM
Yes, I believe it happens if you select cold pixel removal as well as hot pixel removal. I remember seeing this only when I used cold pixel removal; no black cores for me if I only select hot pixel removal. At least that was my experience last time I messed with cold pixel removal a few months ago.
  • fullthrottle_man likes this
#8 Borodog
Borodog
  • Loc: St. Augustine, FL
Posted 11 January 2025 - 10:25 AM
Report this to Robin, please.
#9 amitshesh
amitshesh
Posted 11 January 2025 - 11:10 AM
Over sharpening or aggressive noise reduction would be my guess.
#10 MarMax
MarMax
  • Loc: SoCal
Posted 11 January 2025 - 06:04 PM
Thanks for all the replies. What I posted is straight out of SharpCap saved as a 32-bit FITS. Flat(dark) and dark applied with non-linear gradient removal and satellite removal. I did nothing with it other than open in APP, zoom in, and take a screen grab. And any histogram settings should not matter since it's the 32-bit FITS.
I'll post it up on the SC Forum when I get back home from Darwin.
  • RodgerDodger008 likes this
#11 amitshesh
amitshesh
Posted 12 January 2025 - 08:56 PM
by sheer coincidence last night I was processing my subs in Siril. When I was using its noise reduction algorithm and tried some aggressive settings, it produced these black spots on my stars. So my money is some kind of noise reduction or sharpening.
Mathematically these spots seem to be due to some overflow for overly large values, or values becoming negative causing this discrepancy in drawing it.
