Siril Error in manual stacking
46 replies to this topic
#26 Smurf
Smurf
  • Loc: Croatia
Posted 25 January 2025 - 01:05 PM
Thank you for your time. You didn't have to bother with post-processing...
Must be a problem in cropping, converting or Siril settings.
Did you Convert images to .FITS??
(Also Simb. Link and Debayer checked at me).
Which part you are cropped and did you check normalize?
I tried to be very aggressive on the first sequence crop (same lake your finish crop), but stacking not work.
And btw, How do you see statistics of all images? I only know for single image.
How I do it:
  • Registration: Global star, Homography, Star pairs: 4, Inter.clamping, 492 processed, 205 of 287 registered.
  • Sequence tab. I selected the area with the mouse. Base name, choose Fits, Export sequence.
After that Search sequence and select cropped. Go to Stacking tab and setting like in post #1.
Edited by Smurf, 25 January 2025 - 01:08 PM.
#27 lock042
lock042
    Siril astronomical image processing software
Posted 25 January 2025 - 03:37 PM
I convert dng to FITS with the debayer button checked. Sym link will do nothing here.
The crop looks like that:
I register in two pass. Checking the "relax PSF check" in the dynamic PSF dialog.
  • Smurf likes this
#28 Smurf
Smurf
  • Loc: Croatia
Posted 26 January 2025 - 07:14 AM
Ok, I created a video, shortest I could (3:26 min)
At beginning I show some settings and program version.
https://youtu.be/_y8...?feature=shared
After first fail stacking, at 2:32 min start again and uncheck many of the last (bad) pictures in sequence to correspond your number, then register again. Stacking fail.
At 1:07 min I Show what register do. From normal images made a weird tilted images.
Edited by Smurf, 26 January 2025 - 07:26 AM.
#29 lock042
lock042
Posted 27 January 2025 - 08:27 AM
I have to admit that I'm currently using the “dev” version of Siril.
That said, you should use two-step global registration.
Instead of exporting the cropped sequence, you have a "crop sequence" option in the right click menu.
At this stage, I only had one "MAD is null" image.
#30 Smurf
Smurf
  • Loc: Croatia
Posted 29 January 2025 - 12:13 PM
Thanks for right click->"crop sequence", it is very useful.
I tried to install the dev version, read manual, but I don't know. I downloaded siril-master.zip with source, but it seems must have other external programs to run that source...
Is it worth trying to install dev version, can be that repair my problem?
I tried "Two Pass Global Star" registration like you told me...
I can't believe that not work for me,  because I built a new PC before few months ago...
Also, I not see anywhere that you confirmed your stacking settings:
Method : Average stacking with rejection.
Normalisation : Additive with scaling.
Rejection : Winsorized Sigma Clipping
So, we are considering that it implies.
Edited by Smurf, 29 January 2025 - 12:20 PM.
#31 rj144
rj144
Posted 29 January 2025 - 08:39 PM
It's on the stacking page.
#32 Smurf
Smurf
  • Loc: Croatia
Posted 30 January 2025 - 05:01 AM
What is on stacking page?? Manual for dev? Beginners language please..
I found
https://siril.readth...ion/source.html
https://free-astro.o...p/Siril:install
this is a bunch of codes and programs which not described how to use it and what they are for.
Edited by Smurf, 30 January 2025 - 04:41 PM.
#33 rj144
rj144
Posted 30 January 2025 - 08:15 AM
I found
There is a stacking tab/page in the program.  That's how you stack the image.  It's pretty basic info if you are stacking.
#34 Smurf
Smurf
  • Loc: Croatia
Posted 30 January 2025 - 04:39 PM
So, the program have all that tabs, Calibration, Registration, Stacking tabs... And when hold mouse pointer on every menu, it show help window. I know that.
@lock042
I found
Edited by Smurf, 30 January 2025 - 04:42 PM.
#35 rj144
rj144
Posted 30 January 2025 - 07:18 PM
@lock042
I found
I'm saying that's where you find the stacking settings.  You said you don't know where to find them. "Also, I not see anywhere that you confirmed your stacking settings:"
#36 Smurf
Smurf
  • Loc: Croatia
Posted 30 January 2025 - 07:33 PM
No no. I didn't said that I couldn't find the tab.
That means that I told @lock042 that he didn't tell his current settings in the stacking tab. He doesn't confirm that he have same stacking settings like mine.
Thanks. Sorry for misunderstanding.
#37 Smurf
Smurf
  • Loc: Croatia
Posted 01 February 2025 - 06:52 AM
We can see MAD data on first picture converted, no need to stacking.
@lock042, do you have installed normal version which is not "dev" to try to convert just one pic? I don't know run dev ver.
Did you have stack settings (Method/rejection/Normalization) like mine?
Look how my other sessions have MAD without cropping and this problem session with crop, not have MAD.
#38 Smurf
Smurf
  • Loc: Croatia
Posted 07 February 2025 - 05:00 AM
If no ideas anymore, we can conclude that Siril is an unstable program and it works differently for each user.
For each user stacking is different.
Edited by Smurf, 07 February 2025 - 05:02 AM.
#39 lock042
lock042
Posted 07 February 2025 - 06:07 AM
Siril is a deterministic program. The only variable that is not deterministic is the user.
  • belliott4488 and Smurf like this
#40 Smurf
Smurf
  • Loc: Croatia
Posted 07 February 2025 - 06:58 AM
I did everything like you, but it doesn't work for me, even with a new fast pc.
If you have a suggestion with some settings, I can try and create a video.
Thanks.
#41 lock042
lock042
Posted 07 February 2025 - 07:20 AM
Thanks.
Did you do it with the dev version? I don't think so.
I don't have the time to test with 1.2.6.
  • rj144 and Smurf like this
#42 Smurf
Smurf
  • Loc: Croatia
Posted 10 February 2025 - 04:24 PM
@lock042 I created a video, just for you. 2 min.
Siril dev ver 1.3.6.
Tnx
https://youtu.be/M7f...?feature=shared
#43 lock042
lock042
Posted 13 February 2025 - 04:36 AM
At first step you choose as a reference an image where the statistic failed. This is an error.
Then, you try to stack before applying registration data while a dialog tries to warn you.
Edited by lock042, 13 February 2025 - 04:36 AM.
  • Smurf likes this
#44 belliott4488
belliott4488
  • Loc: MD, US
Posted 13 February 2025 - 07:16 AM
Wouldn't it also be better to crop out all those dark corners? I was expecting to see the cropped rectangle entirely contained within the image circle.
  • Smurf likes this
#45 lock042
lock042
Posted 13 February 2025 - 07:49 AM
There's a risk of losing some of the information due to the significant frame shift. I did the final crop after stacking.
#46 belliott4488
belliott4488
  • Loc: MD, US
Posted 13 February 2025 - 10:30 AM
Ah, okay. I see that your earlier replies state that the MAD algorithm needs at least 50% of the image not to be outliers. I guess those dark corners amount to a good bit less than 50% (?).
  • Smurf likes this
#47 Smurf
Smurf
  • Loc: Croatia
Posted 13 February 2025 - 12:03 PM
I tried more images and apply statistics. I did not found in any picture better statistics (MAD) in that session. Btw, is there a way maybe to see statistics (MAD) of ALL IMAGES AT ONCE (like in DSO)?
I selected a similar picture for reference to yours (target at bottom-left). Because I don't know number of your pic which you are applied. This is similar position.
@lock042 said:
"Then, you try to stack before applying registration data while a dialog tries to warn you.
You told me that I use "2pass", right? When I check that, I leave sequence which Siril automatically creates me (cropped_convert_.seq). But because that, I got a red border around screen. And because that is a warning before stacking.
I think that registration 2pass creates reg files "in" that sequence and there is no other seq to select after registering 2pass.
So, registration was done in "cropped_convert_.seq".
@belliott4488 said:
"Wouldn't it also be better to crop out all those dark corners? I was expecting to see the cropped rectangle entirely contained within the image circle."
I think that is not cropp.
Look carefully post #37. I many times try to cut all black edges, but, I got MAD=0 (sometimes I got 1). And right picture-other session, no crop, MAD=17 :-O
 It must be some stupid wrong settings somewhere in Siril for me. Your all pictures have MAD, my don't have any. That is too strange.
Edited by Smurf, 13 February 2025 - 04:13 PM.
