I recently acquired the 10" Imaging Newt from AT. Since it came from a fellow member, it has a few mods already, some I'll keep, others will probably be reconfigured. The scope is the truss tube model here:
https://astronomics....809e8ac57&_ss=c
One of the mods I'll keep is the addition of the secondary heater. After taking the secondary chassis/holder apart and seeing how it's made, (I had to reassemble the secondary when I received the scope) I'll probably switch it out with an Astrosystems version like my other visual Dob Newt, perhaps with a curved spider. We'll have to see how much I Iove, or hate, the diffraction spikes. I've done a little observing with the scope and the views are really good with a coma corrector, so I'm not swapping out the secondary mirror until I can get some images with the telescope. However, I think the structure could be improved and will help what many on the boards have said about the slipping of collimation with long tracking.
The question is about the possibility of a dew heater on the primary, though. I included an image of the scope so you can see that it is like so many of the truss model CDKs and RCs with the lower structure is only a barrel of sheet metal, 9"-10" deep. I wonder if the AstroZap shroud around the center truss sections will be enough to protect the primary from dew issues? The scope also has 3 small, really small, fans. They look diminutive but move a reasonable volume of air. My 120mm fan on my other Dob/Newt, a full tube type, however, moves considerably more air, so much that you can feel air movement at the secondary of that scope. I have said for some time that I wanted to add a boundary layer fan to that scope but simply haven't done so. I have the fan and all the wiring to complete the project, but someone's gotta start it for me as I just don't seem so motivated!
So will the modest amount of air from the 3 rear fans keep the primary dew-free? Should I consider a boundary layer fan as well? If a heater would be the best, does anyone have any resources or ideas that might help me get a plan together? I know there aren't a ton of these scopes out there but I figure the CDK and truss tube RC guys and gals could chime in with their experiences?
