Prism crack (?) in cheap bino
6 replies to this topic
#1 peaksix
peaksix
  • Loc: Chicago, IL, USA
Posted 16 January 2025 - 04:33 PM
I bought one of those $200 Chinese binoviewers. Upon receiving it, I noticed that there appears to be a small crack on the edge in one of the eyecups. It seems to be internal to the binoviewer as I cannot reach it from the outside (an outer layer of glass blocks access). From searching around CN, I see some mention that these prisms are held in by tiny screws which can cause cracks in some cases. That's my best guess as to what's happening here.
I can't actually see it during usage; it appears to be outside the field of view. I would consider keeping it since it currently seems purely cosmetic. But my fear is that the crack may grow over time. Any advice on what to do?
#2 vrodriguez2324
vrodriguez2324
  • Loc: San Diego, CA
Posted 16 January 2025 - 04:54 PM
Which Binoviewer is it? How do you like it?
I am looking into trying Binoviewers.
#3 astrokeith
astrokeith
  • Loc: Surrey, UK
Posted 16 January 2025 - 04:55 PM
From the photo that doesnt look like a crack. A scratch maybe, or a piece of scarf or similar lying on the surface.
Its too thick and stops abruptly to be a crack IMHO.
If I'm right it won't get any worse!
#4 peaksix
peaksix
Posted 16 January 2025 - 05:31 PM
It's the Omegon. Seems fine. Pretty similar to the other options at that price point. I also bought the Arcturus but returned it because the IPD adjustment range is more limited than the others.
I'm about 95% sure it's a crack, it's just difficult to take a good photo. It has "depth" to it, if that makes sense.
#5 Eddgie
Eddgie
Posted 23 January 2025 - 12:37 PM
Looks like it could be a scratch or a crack, but my money is on scratch. Probe it with a sharp item like a needle. A crack would usually not leave a perceptible grove, but a scratch would.
Just a guess.
#6 AlexSH
AlexSH
Posted 25 January 2025 - 07:35 AM
This is more similar to the failure of the instrument (the counter or adjusting tab on the blackened diaphragm). Improves the technological process during manual assembly. We could tint it, but we need to do more and cheaper. On Chinese ED binoculars I got this on the adjustment wheels, the groove was not evenly trapezoidal and there was a small scratch.
#7 peaksix
peaksix
Posted 27 January 2025 - 04:32 PM
Update: the vendor offered to send me a replacement unit. That arrived today, and unbelievably, it has the same type of defect in the same location (though slightly difference in appearance). I decided to pop off the plastic cover and was able to determine that it is not in the prism, but appears to be internal to the eyepiece holder assembly. But I'm still not quite sure what it is or what caused it.
