ETX70 some failures
Meade Equipment
16 replies to this topic
#1 jab.astro
jab.astro
Posted 19 January 2025 - 02:07 PM
Hi, just landed into CN
I've got a ETX70AT a couple of decades and last two years it has been parked
Let's see whether I am able to explain the symptoms and some findings.
Yesterday I decided to start it up. I connected a 9V power supply to it. When it started up, during alignment it gave a motor failure error. I restarted several times and there was no way. I increased the power supply voltage to 12V using a regulator (since it suggested that the voltage was not enough) and it started to work better, however while it was moving during the alignment I could see that it was having a hard time, and it even stopped. I could not even hear the movement of the motors to maintain the position once a star was located.
I decided to continue manually with the tripod without unlocking anything.
This morning when I started it up, the Meade message appears as you can see in the video (https://www.facebook...978394704185663) and then the image fades and it looks like a movement on the display, but the motors are not heard and the remote control does not act.
I decided to disassemble it (first time) and I found  the declination motor broken (I already found STLs to print it out in 3D). Also I looked into the pcb and did not find any noticeable in the connections but AUTOSTAR does not work.
I will be grateful if someone can give me some idea how to proceed. I will be searching along CloudNight messages to determine the problem although I am not sure about it.
#2 OzAndrewJ
OzAndrewJ
Posted 19 January 2025 - 02:51 PM
Gday jabastro
I dont do farcebook so
What type of handset and what firmware is loaded
( part of the firmware should show during boot )
A motor unit fault during align means the motor has been asked to move
and there is no encoder feedback to say it is moving
This could be a staklled motor, damaged encoder or other things
so step by step.
  • Skywatchr and jab.astro like this
#3 jab.astro
jab.astro
Posted 20 January 2025 - 01:46 PM
Gday OzAndrewJ
Thanks for your prompt replay
Once it starts AutoStar indicates : © 03  Meade  [12S]
#4 OzAndrewJ
OzAndrewJ
Posted 20 January 2025 - 03:21 PM
Gday jab.astro
12S is not something i have heard of
If you can get to the menus, go to the "Statistics" menu to get the ful number
I am assuming you have a 494 ( ie there are no "numbers" on the handset )
If so, there is very little you can currently do, other than try a "calibrate motors"
The handset sends a command to the cards to move the motors and if it gets no feedback
it declares the fault, so at that point, if you have power but no motors move
you need to start tracing signals.
#5 jab.astro
jab.astro
Posted 20 January 2025 - 06:33 PM
Gday Andrew, it is a 494 model how ever I am not able to reach any menu items (is it possible to upload here a video?) you would see that first appears the text aforementioned and thereafter the screen becomes black.
When switched on the device the motors does not move at all.
Is it possible to get the schematics of the handset and the pcb? it would help me to split the problem in different tests to find out what is the problem.
#6 OzAndrewJ
OzAndrewJ
Posted 20 January 2025 - 07:11 PM
Gday jab.astro
IIRC, There are some "rough" schematics on the weasner site
but there are a few minor errors.
Attached File  494BUNDL.doc   74KB   8 downloads
A few of us are currently trying to dig into the 494s so we can update the firmware
without needing the Meade code to be working ( but the chips etc must be OK )
Ifyou can make a few pigtails etc, there are other ways to test the CPU,
but for initial testing,the schematics should be OK
#7 jab.astro
jab.astro
Posted 21 January 2025 - 07:11 PM
Gday Andrew
Thanks a lot for the document, I will try to understand the schematics in order to be able to check out whether the circuit is ok or not. Currently I am not able to enter the menus,
Is there any diode/fuse that could be damage in case of a problem with power source?
#8 OzAndrewJ
OzAndrewJ
Posted 21 January 2025 - 07:48 PM
Gday jab.astro
No fuse, no diode, no reverse polarity.
Can you make simple RJ plug pigtails or wire harnesses ????
What control panel sockets do you have???
( Looks like a std 8pin for the handset and 4 pin ( Aux )??? )
Unlike the 497s, there are special boot tests that can be run
to test things, incl a handset test.
If you want to try them first, its very easy, but you need access
to the clock and data lines in order to short them during boot
( vs hold down keys )
For the handset "self" test, you need access to the Az clock line )
Edited by OzAndrewJ, 21 January 2025 - 07:48 PM.
#9 jab.astro
jab.astro
Posted 22 January 2025 - 05:16 PM
Gday Andrew, thanks for your comments.
I will try to find as much information as possible (schematics and so on) to test Autostar and motors as you suggests
Juan, Almassora, Spain
#10 jab.astro
jab.astro
Posted 23 January 2025 - 11:56 AM
Attached you can find the sequence of the starting up of Autostar in three pictures ( I can not upload a video)
I found an article related to a tantalum capacitor (https://www.cloudyni...or-issue-as494/), could it be this a symptom of a similar problem?
Step1: Screenshot 2025-01-23 at 17.47.04.png
Step2: Screenshot 2025-01-23 at 17.47.09.png
Step3: (I switched off) Screenshot 2025-01-23 at 17.47.21.png
Edited by jab.astro, 23 January 2025 - 11:57 AM.
#11 OzAndrewJ
OzAndrewJ
Posted 23 January 2025 - 03:22 PM
Gday Jab.astro
OK, as it works initially, it looks like your brightness and contrast are set too low.
They start at full values but then drop back when running
When the screen is dark,can you look at it at a grazing angle in bright light
You may need tochange its angle relative to the light, but often you can see
the texts, even tho the LEDs are off.
#12 jab.astro
jab.astro
Posted 08 February 2025 - 05:23 AM
Gday Andrew
I found an article related to Tantalum Capacitor (https://www.cloudyni...or-issue-as494/) in which you mentioned about resetting the 494 , how could I get that information to try to bring to life the device? thanks
#13 OzAndrewJ
OzAndrewJ
Posted 08 February 2025 - 03:51 PM
Gday Juan
If the mount starts and beeps or shows ANY text at all,
then what we mentioned re "recovering" a handbox will not work
as the fault it fixes renders the handset dead ( ie it never shows any text or beeps )
Yours sounds like it is something else.
The method does allow you to investigate the existing code
and test if memory is working etc, but it wont be a "fix", just a means for investigating.
To do it requires a third party app ( free ) and the ability to connect wires
to the clock and data lines in the handbox.
This can be done several ways, but you would probably need to make up an adapter
of some sort. Very easy if you have the gear and play with this stuff al the time,
but otherwise, might need some help to make the bits
#14 jab.astro
jab.astro
Posted 08 February 2025 - 05:01 PM
Gday Andrew, thanks for your comments. Yes indeed, it shows fulltext one second and thereafter it leaves the unit in an undetermined state. I removed the tantalum and verified, and also replacing just for testing with a electrolitic capacitor but the result was the same.
I am trying to find a new autostart 494 as I presume that repairing it will not be feasible. I gather that it is not way to reset the unit using the keyboard (I tried the safe mode but it seems not working)
#15 OzAndrewJ
OzAndrewJ
Posted 08 February 2025 - 06:40 PM
Gday Juan
If its not working, you cannot easily reset using the keyboard.
Being a 494, there is a way to trigger a reset by shorting cables on boot
but it requires basic code to be working.
No harm trying, but its not sounding good.
Sooo, you need to find a way to short both the Alt and Az clock lines to ground
and then boot the handset.
It will carry out an internal keytest where you are asked topress keys
On finishing, it does a memory protection test
If it gets past that, it puts "StarFinder/Autostar 494" on the LCD
and then resets the EEProm to do a full reset on next boot.
If it doesnt get that far, you may have damaged FLASH
and the third party app can check for that, but again, you need direct access
to the clock and data lines to do that.
#16 jab.astro
jab.astro
Posted 08 February 2025 - 07:08 PM
Gday Andrew,
thanks again, is there any document that could explain where  and how to short Alt/Az clock lines to ground? and which are the clock/data lines?
Juan
#17 OzAndrewJ
OzAndrewJ
Posted 08 February 2025 - 08:18 PM
Gday Juan
There are lots of details on the port and handset pin functions
Ref attached piccy of a port that the 494 cable would plug into
( ref the panel port, not the Hbx port )
https://www.cloudyni.../#entry12220506
From that you can tell what pins do what
Another user made up a simple remote power supply
using a single RJ45 socket for this sort of work,
and others who had older mounts with exposed Alt and Az connectors made pigtails
https://www.cloudyni.../#entry13806347
Whatever way you go, you MUST be ultra careful not to get the polarity wrong.
Check 3 times then check again
  • jab.astro likes this
Also tagged with one or more of these keywords: Meade, Equipment
