I have a Skywatcher Star Travel 120. I like the scope, but I would like some upgrades. I have a Celestron twist lock 2in diagonal and have collected most of Explore Scientific's 82 degree eyepieces. They all work with the scope, but the stock visual back seems really cheap to me and I have some issues with how secure the two grub screws secure the diagonal (or not). The focus travel is almost to the minimum with the larger eyepieces.
I would really prefer a compression ring visual back but am having a bit of trouble. I got a Baader 4-in1 back https://agenaastro.c...ck-2458190.html which seems really well made and holds things more securely than the stock, but the problem is that it is about 10mm or so longer than the stock back. This seems to mean that the larger eyepieces cannot achieve focus (not sure if it's all, or just the 14mm and larger).
I need to somehow shorten the optical path, either with a shorter, more compact visual back, or with a different diagonal.
I haven't had much luck finding a visual back, and the few that might be around don't give info about length or are no longer available. There also doesn't seem to be any info about optical path length given for diagonals.
Any suggestions? I'd prefer to stick with 2 inch.
