In another thread someone asked for pictures of my rig, so here they are. But I would be interested in seeing other people's rigs as well, as well as descriptions of how they have gone about solving different problems.
This is my 1100 EdgeHD, riding on my CGEM. Under the snout, screwed to the dovetail plate with a 1/4"-20 screw, is an SVBONY SV165 30mm guide scope with an SV305 camera, used as an "electronic finder." It's used for plate solving, slewing, and syncing the mount, plus visual fine adjustment of the pointing to get on target. Because the SV165 does not have adjustable rings, I can't align it exactly with the main camera. That's where the green laser pointer mounted in the top side finder shoe comes in. It's made for use as a rifle laser sight, and hence has very fine pointing adjustments. So the GLP is aligned with the main imaging camera. In SharpCap, I plate solve and slew to the target (say Jupiter), which centers Jupiter in the SV305. Then I briefly switch on the GLP and place SharpCap's crosshair reticle on the tip of the laser in the SV305's field of view. Then I just manually slew the target over to the crosshair position and voila, the target is in the main camera's FOV. The electronic finder + GLP combo allows me to polar align, slew & sync and get on target in about 2 minutes.
The optical train is currently a GSO dual speed Crayford focuser with an EAF attached with a bracket from Buckeye Stargazer (this avoids mirror shift when focusing, although that was always minimal with this scope), ZWO ADC (via an M42 - 2" adapter to 2" extension tube slid into the GSO's compression ring; I would prefer threaded connection to the focuser body, but alas it is unavailable with the GSO), 2" filter drawer (for swapping UV/IR cut filter for an IR685 pass filter), to the ASI678MC. The ADC-filter drawer-camera are all threaded, meaning this configuration has little control of the camera orientation. I used to use a camera rotator in there, but it added 11mm of back focus, and I am already out of spec a bit because of the length of the GSO Crayford, which can start to matter for lunar imaging; the 1100 EdgeHD has a 146.5mm back focus and I am already slightly above that at full retraction of the focuser. If I ever get around to using the ASI676MC, it has a built in UV/IR cut filter, and I can swap out the filter drawer for the slimmer camera rotator and kill two birds with one stone.
Thermally, I use a simple plastic & velcro dew shield in conjunction with 2 layers of Reflectix and an R-Sky dew strap & controller. I live in a swamp in Florida (literally; where my neighborhood is used to be a swamp), so I have their heavy duty dew strap & controller. However, I actually need very little heat to keep the dew at bay because of the shield and insulation. The strap is installed underneath the insulation, direction on the OTA behind the corrector cell. In the future I will be moving it to the middle of the OTA between the corrector and primary mirror.
The cables for the SV305, the EAF, the main camera, and the dew strap are bundled into a sort of umbilicus. The cable for the dew strap splits off and goes to the dew heater controller, which is just strapped to the hub of the mount with velcro. The SV305, EAF, and the dew heater controller are all plugged into a powered USB hub that rides on the tripod spreader. The hub and the main camera cable are plugged into USB3 ports on my laptop. A USB to RS232 adapter cable connects the laptop to the hand controller of the CGEM, allowing SharpCap to control the mount via ASCOM for plate solution, slewing, and guiding.
I am happy to answer any questions about this rig. It has evolved a lot and is still evolving over time. I would also very much like to see other people's approaches to this hobby.
I don't have a permanent observatory, so the rig gets broken down, carried outside, and setup whenever I want to image. Moving at a leisurely pace it take about 15 minutes to set up.
Edited by Borodog, 22 January 2025 - 12:30 PM.
