YOUR Most Immersive Eyepieces
173 replies to this topic
#1 Nut2But
Nut2But
Posted 24 January 2025 - 02:47 PM
Just sitting here pondering eyepieces. And the thought of immersion came to mind. A quick google search returned a post from 15 years ago. So I thought I would re ask the question to see if things have changed at all as new eyepieces have come along.
What are some of the most immersive eyepieces you’ve used?
I know the term is very subjective. But none the less it is one of importance to some. Not looking to start fights here. I’m just curious what everyone’s thoughts are. I personally seek to lose awareness of where I’m at when viewing to get lost in the stars and would like to know which eyepieces might give me the best chances of that happening.
Take Care
Tyler
#2 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 24 January 2025 - 02:55 PM
In no particular order: 17mm ES92, Masuyama 16/85, Masuyama 26/85.
I have other wide-fields, but these stand out.
Clear skies!
Thomas, Denmark
  • Dave Mitsky, weis14, manolis and 5 others like this
#3 truckerfromaustin
truckerfromaustin
  • Loc: Wherever I park my truck for the night.
Posted 24 January 2025 - 03:06 PM
My 40mm Swan 70 degree afov and my Luminos 23mm 82 degree afov are my best answers to this depending on which scope I'm using.
Clear Skies
Edited by truckerfromaustin, 24 January 2025 - 03:59 PM.
#4 StephenVP
StephenVP
  • Loc: Fremont, CA
Posted 24 January 2025 - 03:17 PM
To me immersive means it gives you the impression of being a portal to a real place rather than just a flat, pretty picture.
My AT28 UWA certainly qualifies. I find Morpheus to be very "portal-like". At first glance one might assume wide apparent fields bring about this quality but I have seen it in narrow field orthos. Whatever gives the image depth of field as if you could reach in and grab a handful of stardust is what I call immersive.
~Stephen
  • Dave Mitsky, manolis, scout and 4 others like this
#5 CrazyPanda
CrazyPanda
Posted 24 January 2025 - 03:26 PM
In this order:
1. 17mm ES92
2. 12.5mm & 17mm Nikon NAV-HWs (17 only when used without a Paracorr)
3. Docter / Noblex
4. 31 Nagler (only when used without a Paracorr)
5. De-cloaked DeLites in a binoviewer - talk about a portal effect! Only thing that breaks the immersion is that it's hard to hold your head in the right place. However, that's also the thing that makes them immersive. Double-edged sword there.
  • doctordub, manolis, Procyon and 1 other like this
#6 NiteGuy
NiteGuy
  • Loc: Northern Arizona
Posted 24 January 2025 - 03:45 PM
I have the 9mm, 14mm and 17.5mm Morpheus eyepieces and they all provide that wonderful "immersive" feeling where the eyepiece just seems to get out of the way when you're looking at objects. The nice comfortable eye relief certainly contributes to the immersive effect and that effect is best when the eye guard is rolled down. I also have a 4.5mm Morpheus but that doesn't provide the quite the same feeling (probably due to the tiny exit pupil size when using that eyepiece on most scopes).
Some observers hate the word "immersive" but I've always felt it's a perfect descriptor. That holds especially true when side-by-side comparing the Morpheus line to other quality eyepieces.
  • jeffmac, ABQJeff and vrodriguez2324 like this
#7 rgk901
rgk901
  • Loc: Beautiful Bortle 10 Midwest Skies
Posted 24 January 2025 - 03:48 PM
think that would be my 100 XWA's since I have to get my eyeball right up in there and than bam! sea of stars
morphs close second but since eye relief is so far up I see my surroundings sometimes at home ( I like to observe cups down for that slim edge) but at dark skies it's not an issue since it's darker around me.
  • vrodriguez2324, f18dad, Mike Q and 2 others like this
#8 25585
25585
Posted 24 January 2025 - 04:41 PM
48mm Brandon
40mm Pentax XW
40mm TV Wide Field
40mm Rodenstock
40mm Vernonscope Erfle
30mm Pentax XW
30mm APM UFF
17.5mm Morpheus
17mm ES92
12.5mm Noblex
12mm ES92
9mm Morpheus
  • doctordub and Procyon like this
#9 areyoukiddingme
areyoukiddingme
Posted 24 January 2025 - 04:44 PM
I think of emersion being in part caused by the eyepiece having an exit pupil that is very easy to acquire and maintain. Another part for me is that I can see a crisp field stop should I decide to go looking for it, and that there are no obvious/jarring aberrations, like edge of field brightening, lateral color, and astigmatism.
My list is similar to the panda's .. .
17 Nikon HW in my Televue 101.
16.5 Pentax XW in anything.
12.5 Docter, in anything.
I would sort of think of adding my Leica zoom, but the fact that changing the magnification is always in the back of my mind is always a bit of a distraction, though a useful one.
Having said all of that, I can think of a case where none of this was true, but the view was so compelling that I forgot about the lack of optical perfection. That was Andromeda in my 80mm refractor with 30mm ES 82. There was a huge bright ring around the edge of the field, perhaps caused in part by field curvature. But the view showed me obvious dust lanes, as well as obvious satellite galaxies. I sat transfixed for half an hour.
  • doctordub, Procyon, vrodriguez2324 and 1 other like this
#10 sanbai
sanbai
  • Loc: Antwerp area, Belgium
Posted 24 January 2025 - 04:51 PM
I don't know now if it's my most immersive eyepiece, but the Nagler 22 T4 comes to my mind.
I guess the approximate recipe for that is not too much magnification, wide apparent field, comfortable, generous eye relief.
The Ethos 17 would be also on my list, but I haven't been out in a good while. I need a refreshment!
Edited by sanbai, 24 January 2025 - 04:53 PM.
  • weis14 and f18dad like this
#11 havasman
havasman
  • Loc: Dallas, Texas
Posted 24 January 2025 - 04:57 PM
All when matched with the right scope & object for the moment:
31T5
Ethos/Ethos SX & XWA's
So, everything I use except for solar.
  • Joe in Gatineau likes this
#12 sevenofnine
sevenofnine
  • Loc: Santa Rosa, California 38*N., 122*W.
Posted 24 January 2025 - 05:26 PM
It's a 2" ES 28/68 for me. No matter which scope it's in, I'm always immersed wink.gif
  • eklf, Procyon, rfcooley and 2 others like this
#13 dave253
dave253
  • Loc: Australia 28.24S 153.25E
Posted 24 January 2025 - 06:11 PM
I like the ES 18/82, I don’t think I’d benefit from going any wider.
It also works great with the 2” ED Barlow element attached in my ST 120, which gives about 50x (haven’t measured it).
  • therealdmt likes this
#14 vrodriguez2324
vrodriguez2324
  • Loc: San Diego, CA
Posted 24 January 2025 - 06:18 PM
According to the Oxford English Dictionary (OED) the earliest evidence for the word 'Immersive' can be traced to 1635 in the book titled "Speculum Mundi, or, A Glasse Representing the Face of the World" written by John Swan who was a Church of England clergyman and encyclopaedist.
https://archive.org/...ge/186/mode/2up
In a section titled "Of Rain" he wrote: "the Sunnes immersive heat doth so boyle the water in the cloud" (p. 149).
In modern written English the word immersive appears about seven times per million words. I wonder what the frequency of the word is in the Cloudy Nights forums.
Okay...back to the OPs question.
What does immersive mean according to the OED:
With reference to an audience's experience of art, entertainment, etc.: providing a sense of being surrounded by or a part of that which is presented. Also more generally: engaging one's full attention or interest; absorbing, engrossing.
In that case, I find the EPs in my main case to all be immersive and have selected those because of this subjective quality (and due to their objective optical quality).
31NT5 - 22NT4 - 14M - 9M - 6.5M - 4.5M
Edited by vrodriguez2324, 24 January 2025 - 06:21 PM.
  • Sarkikos, Lentini, areyoukiddingme and 3 others like this
#15 vdog
vdog
  • Loc: California Central Valley, U.S.A.
The ES 92 12 for sure.
A close second:  the Morpheus 12.5 and 9.
  • Procyon, 25585 and gmoney like this
#16 areyoukiddingme
areyoukiddingme
Posted 24 January 2025 - 06:58 PM
Looks like there was a tiny blip around 1770
  • Jeff Morgan and vrodriguez2324 like this
#17 Kutno
Kutno
Posted 24 January 2025 - 07:26 PM
Naglers and Ethos
#18 rfcooley
rfcooley
  • Loc: Great Basin Desert, NV
Posted 24 January 2025 - 07:48 PM
I have a Svbony 26mm/70* 2" works great in all of my OTAs. At least the ones it will fit in.
RF
#19 fishhuntmike
fishhuntmike
Posted 24 January 2025 - 09:35 PM
Others beat me to it. ES 92 17mm because I wear glasses for astigmatism and love the eye relief.
  • Procyon and 25585 like this
#20 Finbarius
Finbarius
  • Loc: Atherton Tablelands, Far North Queensland, Australia
Posted 24 January 2025 - 10:55 PM
For me it is the pair of Masuyama 16mm (85°) in the MaxBright II binoviewer: magnification, exit pupil, TFoV°
Sky Rover 130mm (f/7) with GPC 1.25 [=1.2×] : 69×, 1.88mm, 1.22°
Tak FOA-60Q (f/15) with GPC 1.25 [=1.2×] : 68×, 0.89mm, 1.25°
CFF 105mm (f/6) with GPC 1.25 [=1.2×] : 47×, 2.22mm, 1.78°
Tak FOA-60_ (f/8.8) with GPC 1.7 [=1.44×] : 40×, 1.51mm, 2.12°
  • Astrojensen and balcon3 like this
#21 aatt
aatt
  • Loc: CT
Posted 24 January 2025 - 11:04 PM
My ES 100 degree eyepieces are pretty immersive.
30mm Sterling Plossl is a very fine 2” ep and very good for faint fuzzy work.
#22 TayM57
TayM57
  • Loc: Stellar Cartography, U.S.S. Enterprise NCC 1701-D
Posted 24 January 2025 - 11:28 PM
The most immersive EPs I've ever used have all been 100° EPs.
  • Procyon, Epick Crom and Roman M like this
#23 manolis
manolis
  • Loc: Greece
Posted 24 January 2025 - 11:33 PM
for me it will be the 12.5 Nikon NAV-HW ,when i position my eye and head right for relaxing views , it's like it draws you in space and not just a picture, I've yet to try my new masuyama's 16 85* in my binoviewer. it will have to wait until spring.
  • Procyon, areyoukiddingme and 25585 like this
#24 Astro-Master
Astro-Master
  • Loc: San Diego County,Ca.
Posted 25 January 2025 - 02:43 AM
My 17 Ethos 122x in my 18" Obsession Classic and used with my AP Barlow any power between 214x to 305x is possible, making one immersive Ethos to become many.
Edited by Astro-Master, 25 January 2025 - 03:07 AM.
  • Jon Isaacs, Joe in Gatineau and Epick Crom like this
#25 Cielo_nocturno
Cielo_nocturno
Posted 25 January 2025 - 07:36 AM
Explore Scientific 25mm 100 degree for sure
  • Procyon, jochsner, 25585 and 1 other like this
