YOUR Most Immersive Eyepieces
173 replies to this topic
#151 vahe
vahe
  • Loc: Houston, Texas
Posted 27 March 2025 - 04:18 PM
I believe you can remove the 2" skirts, which saves weight.
Correct, If I am not mistaken Jon Isaacs showed me how to do it.
Vahe
#152 rowdy388
rowdy388
  • Loc: Saratoga County, NY
Posted 28 March 2025 - 10:28 AM
I removed the skirt of my 22 Pan, but put it back on after seeing how light it was. In a 2" focuser the adaptor would definitely weigh
a lot more, and I could spare myself fiddling with an adaptor because I often only use 2" eyepieces. Then a couple years later I removed
the skirt again so I could use the Pan in my 1.25" finder scopes and the 6" F/8 which only has a 1.25 focuser. This time I'll leave it off
for maximum flexibility. It is an awesome eyepiece.
#153 Vertigo
Vertigo
  • Loc: United States of Europe
Posted 28 March 2025 - 12:35 PM
Hello,
I'd like to throw some salt into the wide-field community: Takahashi TPL 50mm.
Andreas
  • Procyon, Lentini and 25585 like this
#154 TayM57
TayM57
  • Loc: Stellar Cartography, U.S.S. Enterprise NCC 1701-D
Posted 02 April 2025 - 09:40 PM
Welcome back! Easily my most immersive EPs
Edited by TayM57, 02 April 2025 - 09:44 PM.
  • nkoiza, Illinois, Procyon and 2 others like this
#155 snakehelah
snakehelah
Posted 03 April 2025 - 10:12 AM
The "short eye relief fan club" would be happy to subsidize your laser eye surgery if you were ever so inclined to join our side
Thanks for the answer !
Clear skies
Do people that partake in visual astronomy that wear glasses actually opt for those surgeries though? I've had some friends who, while happy with the surgery outcomes had poorer night vision after their surgeries - not that it mattered to them. But I noticed I had no issues around dark environments while they were fumbling to get a light on and it was quite strange.
Edited by snakehelah, 03 April 2025 - 10:13 AM.
#156 davidgmd
davidgmd
  • Loc: Maryland
Posted 03 April 2025 - 01:21 PM
The problem with LASIK and PRK for the visual astronomer is that the dark adapted pupil may be larger than the central laser treatment zone. If that happens, some of the light will pass through the transition zone between treated and untreated cornea, resulting in unwanted aberrations. It may affect driving at night more than astronomical observing, but it’s hard to predict if or how much it will affect a given individual. It’s not as simple as comparing treatment zone size to dark adapted pupil size due to variation in healing and in visual processing.
I was fairly conservative and never did refractive surgery on visual astronomers, but I know others would.
  • russell23 and 25585 like this
#157 TayM57
TayM57
Posted 03 April 2025 - 01:51 PM
Which is why I've never opted for LASIK or other corrective surgery. The risk to my nighttime hobby is just too great.
  • Lentini, 25585 and davidgmd like this
#158 saemark30
saemark30
Posted 03 April 2025 - 02:27 PM
Hello,
Andreas
Ditto. 2" Brandon 48mm.
  • Procyon, 25585 and Vertigo like this
#159 Astroman007
Astroman007
  • Loc: Latchford, Northern Ontario, Canada
Posted 13 April 2025 - 02:31 PM
Right now: 21mm Ethos, 17mm Nikon NAV-HW, 13mm Ethos, 48mm Brandon (sensitivity to eye placement aside), 28mm Edmund RKE.
Also have 31mm Nagler and 40mm Pentax XW that I haven't used yet. Based off specs they are part of the list, but won't formally add them until I've used them personally.
  • Procyon likes this
#160 25585
25585
Posted 17 April 2025 - 10:43 AM
I am still tempted to try an ES100 25mm, now Meade 26mm MWAs have gone. There seem to be no other brands that have the Meade's optics.
#161 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 17 April 2025 - 10:48 AM
Bear in mind they claimed 100° and delivered 88°.
And the 26mm was panned by every review I've read.
The ES 25mm is not glasses compatible.
Edited by Starman1, 17 April 2025 - 10:53 AM.
  • Mike W and 25585 like this
#162 25585
25585
Posted 17 April 2025 - 10:55 AM
The Panoramas only go up to 23mm though.
#163 Starman1
Starman1
    Stargeezer
  • Loc: Los Angeles
Posted 17 April 2025 - 11:01 AM
I deleted the Panorama reference. They were Luminos eyepieces in another shell.
  • 25585 likes this
#164 Highburymark
Highburymark
Posted 17 April 2025 - 04:37 PM
I’ve just spent a happy hour absorbing the Beehive through my TSA-120 and Nagler 22mm T4. It was, to my eyes, perfect. Perfect stars to the edge, perfectly framed, perfect eye relief adjusted to my needs.
  • Mike W, payner, JeremySh and 1 other like this
#165 TicoWiko
TicoWiko
Posted 18 April 2025 - 11:19 AM
I think you're touching on something important here : framing on certain specific objects. That really matters in terms of immersiveness. Not so much the exit pupil, but really just the framing in terms of FOV and how much it draws you into the object. I remember the very specific way switching straight from my 20mm XWA to 5mm XWA when hunting for M11 radically changed the view. The sudden shift from blurry smudge to full blown starfield was mindblowing. And if the 5mm XWA wasn't on a 10" newt with a Paracorr 2, the experience and in particular the immersiveness, mostly due to framing, would've been radically different. Meaning most of the choices here would likely be very different if the night sky were visually differently populated.
Edited by TicoWiko, 18 April 2025 - 05:16 PM.
  • Highburymark likes this
#166 Jon Isaacs
Posted 18 April 2025 - 01:31 PM
Luckily not all eyepieces need that help.
It's not the eyepiece that needs the help . A steady head and upper body go a long way in providing steady views, particularly at high magnifications.
  • 25585 likes this
#167 Dave Mitsky
Dave Mitsky
Posted 18 April 2025 - 02:20 PM
The following are the eyepieces that I own that I find to be immersive: the 5mm Pentax XW, the 7mm Pentax XW, the 9mm Astro-Tech XWA 100°, the 12.5mm Baader Morpheus, the 13mm Tele Vue Ethos, the 17.5mm Baader Morpheus, the Astro-Tech 20mm XWA 100°, and the 28mm Astro-Tech UWA 82° and to a somewhat lesser degree, the 6, 8, and 10mm Tele Vue Delos and 35mm Tele Vue Panoptic.
At one time, I had a 20mm Tele Vue Type 2 Nagler, which I found to be immersive.
  • Jon Isaacs and Procyon like this
#168 Dave Mitsky
Dave Mitsky
Posted 18 April 2025 - 02:33 PM
I've always enjoyed looking through a friend's 30mm Leitz Planokular 88°.  I don't find the 28mm Edmund RKE particularly immersive, but the floating effect is certainly interesting.
#169 rowdy388
rowdy388
Posted 18 April 2025 - 03:00 PM
I haven't used my 20 APM XWA in over a year and forgot how much I used to enjoy it until reading this thread. I'll have to
slip it into the focuser next time out to get reacquainted.
  • Jon Isaacs and TicoWiko like this
#170 Jon Isaacs
Posted 19 April 2025 - 04:02 AM
:waytogo:
The 20mm XWA and the 21mm Ethos seem the most immersive.  The bright, near richest field combined with the 100 degree field is a great combination. In my largest scope, that's 140x with a 4mm exit pupil and a 0.71 degree TFoV, stars are really bright and it's enough magnification for globulars to begin to come alive. Eyepieces like the 31mm Nagler and the 28mm UWA are also quite immersive but for me, the 20mm Hyperwides are my favorites.
  • rowdy388 and f18dad like this
#171 Highburymark
Highburymark
Posted 19 April 2025 - 05:07 AM
I bought the Nagler 22 specifically for the few brighter clusters that are visible from my urban location. Definitely think framing’s an important part of immersiveness - though can also appreciate those who prefer hyperwides.
  • Matthew Trail likes this
#172 25585
25585
Posted 19 April 2025 - 08:06 PM
Agreed, but its preferable to not be ergonomically restricted, the more latitude and ease the better.
#173 Jon Isaacs
Posted 20 April 2025 - 11:59 AM
The basic problem is that the exit pupil has a certain diameter and your pupil has a certain diameter, getting them properly lined up so the exit pupil is centered in your pupil requires millimeter precision. That's best done either seated or standing with some support for the upper body.
  • 25585 and JeremySh like this
#174 25585
25585
Posted 21 April 2025 - 08:52 AM
OK, but I find eye pupil and exit pupil alignment easier in some eyepieces than others. The eyepieces I own and use, are the easy ones, and I am glad there are enough now, it was an expensive quest!
Edited by 25585, 21 April 2025 - 08:54 AM.
