Venus & Neptune / Moon & Saturn - 1/31/25
6 replies to this topic
#1 B 26354
B 26354
  • Loc: Southern California semi-desert 33.75° N (NELM mag 5.3)
Posted 01 February 2025 - 02:38 AM
Just the slightest bit hazy this evening... but still a lovely set of sightings, since the late-afternoon's partial cloudiness had obligingly dissipated shortly after full darkness had settled upon the western sky. Even better... at just past 6pm, it was a pleasantly tolerable 55°F.  grin.gif
Saturn, at mag 1.1 and 1.5-degrees from the 2.5-day-old Moon, was easy to spot naked eye... and the pairing made for a charming and enjoyable duo in my 15x70 Celestron SkyMaster Pro ED.
This slightly-cropped, less-than-spectacular shot was taken with a tripod-mounted Askar ACL200 astro-lens and an Olympus OM-1. 1/4-sec at f/4 and ISO1600.
In spite of their huge difference in brightness... the Venus/Neptune duet was only a bit more difficult. I'd plotted Neptune's position using SkyMap12 Lite... and thankfully, at 3.3-degrees distance from mag -4.6 Venus, it was in a relatively uncrowded section of sky, with Mag 7.9 Neptune forming an almost-right-angle triangle with two nearby stars of similar magnitude (7.6 and 8.9).
This was the first time I'd spotted Neptune in the Celestron 15x70s... but thanks to their excellent sharpness and contrast, I was pleasantly surprised to so easily detect the dim planet's obvious greenish-blue hue, as compared with the yellow-orange glow of the two neighboring stars.
The views of both groupings through the binoculars were infinitely nicer than my mediocre photos... but clicking on them will probably help.
  • Dave Mitsky, Rich V., Erik Bakker and 3 others like this
#2 Terra Nova
Terra Nova
Posted 01 February 2025 - 11:31 AM
This slightly-cropped, less-than-spectacular shot was taken with a tripod-mounted Askar ACL200 astro-lens and an Olympus OM-1. 1/4-sec at f/4 and ISO1600.”
That’s a great pic! I like it!
  • B 26354 likes this
#3 treadmarks
treadmarks
  • Loc: Southern NH
Posted 01 February 2025 - 01:56 PM
I was clouded up last night but I noticed this trio will be separated by about 3 degrees this evening and it will be clear. Doable with my AT72 and the temp will not yet be near the overnight drop of -3 F so I will be attending
#4 B 26354
B 26354
Posted 01 February 2025 - 05:01 PM
And the Moon shouldn't be so bright that it washes out Neptune... at least not visually. Hope you get to see them!
Edited by B 26354, 01 February 2025 - 05:04 PM.
#5 treadmarks
treadmarks
  • Loc: Southern NH
Posted 01 February 2025 - 08:58 PM
No visual or photographic aids were needed for this - the two were a pretty sight in the sky. I did bring out my camera for this event though, and I don't often do astrophotography.
Pretty sure I was able to locate Neptune below Luna with my AT72, but could not resolve. They did all fit in the 5deg field though.
Nikon D7500 SLR with 300mm telephoto:
#6 Dave Mitsky
Dave Mitsky
Posted 01 February 2025 - 11:43 PM
The Moon and Venus were spectacular tonight. I also observed the 5 other planets in the so-called planetary parade and a number of DSOs using a 5" refractor and a 17" classical Cassegrain at the Naylor Observatory.
  • MrSyzygy likes this
#7 B 26354
B 26354
Posted 02 February 2025 - 12:03 AM
Good job!
I spent about an hour watching the lovely Venus/Moon conjunction with my Stellarvue 80, my APM 20x70s, and my hand-held GPO 8x56s. Knowing that Neptune was making an "almost" equilateral triangle with the Moon and Venus, I knew exactly where to look... but it was a little bit hazier here tonight than last night, so the glare from the Moon washed it out, and I was never able to definitively spot it... even though last night it was quite obvious.
