or if leaving them on will trap moisture that the desiccant bags can't get to.
This is a great question, and it depends on the design of the cap.
In my original case, I kept a 100g silica gel pack in it and took all precautions to keep it dry.
But one day after the EPs had been in storage for a month (fresh silica gel pack) due to bad weather, I took the cap off my 17mm Explore Scientific 92 only to find fungus had grown on the eye lens.
The interior of the case was dry - all the other eyepieces were fine, it was just the ES92.
Turns out that the ES92 eye guard and cap design creates a PERFECT rubber seal. Whatever the relative humidity of the air trapped under the cap is, is how it will remain. The silica gel won't help.
However, many eyepiece caps offer ridges that create small gaps that allow the lenses to breathe. These usually are fine.
But, the stock caps of the Takahashi TPLs and TOEs create a solid seal around the eye guards. I needed to remove the eye guards to buy back some eye relief, and I 3D printed new caps that take air flow into consideration:
Note the little vents? The cap does not sit flat on top of the eyepiece, so there is ample air flow.
So should you keep the caps on or off?
You should definitely keep them ON for three reasons:
1. Avoids accidentally touching the glass with your finger when retrieving an eyepiece
2. That foam can break down and can deposit gunk onto the lens overtime
3. If the foam makes contact with the lens, you'd be constantly rubbing the coating with the foam every time you take the eyepiece in and out. I can see it dulling the coating over time.
That being said, I think you should absolutely drill some vent holes in the caps if you find that they are sealing tight against the rubber or the bottom of the eyepiece. "Dust caps" are less about preventing dust (your eyepieces are going to get dusty during use anyway), and more about preventing the things I mentioned above. But you do want to ensure they allow for air flow.
Any other proper storage tips are welcome, as well as specific criticisms of how I'm storing mine. Feel free to call me an idiot (with helpful explanations) if you see anything wrong with how I'm storing them.
I would replace the open-cell PU foam with closed-cell PE foam (like Kaizen foam). The open cell stuff absorbs and holds onto moisture like a sponge. The closed cell stuff does not.
You desiccant may not be all that effective because when your case it closed there is no air circulation.
You don't actually need air circulation for desiccant to work. Moisture, like heat, will seek equilibrium in a closed environment. The desiccant pack pulls in moisture from the air directly adjacent to it. Now that air is low in moisture while the air next to that is higher in moisture, so moisture will diffuse from high to low, and so on and so forth. Eventually the whole case will be dry, and will be below the fungal growth level of RH within a few hours.
All of my cases seal and are IP67 waterproof. During the summer, relative humidity is about 70-80% for days on end.
If I put a fresh silica gel pack in the case along with a hygrometer and wait about 12 hours, the case will be around 40% humidity. If I wait a few days, it will eventually drop down to ~15% humidity which is the lowest my hygrometer will even measure, meaning the actual RH in the case is probably single digits. No air circulation required. That said, I would be willing to bet that even minor temperature fluctuations creates thermal currents that naturally circulates the air in the case anyway.
Because the cases seal, it will stay that way indefinitely. I don't have to worry about the silica gel pack saturating and ceasing to work, because the case is non-permeable. I can throw the pack in, and keep the case closed for years on end if I want to.
During regular use, if I take the time to put the pack in a plastic baggie, I can make it last a lot longer. If I'm lazy and let it be exposed to outdoor air, it will saturate after just a couple of sessions. That's ok, I can just put a fresh one in and recharge that one.
Edited by CrazyPanda, 02 February 2025 - 03:49 PM.
