A setup I've built last year
A spectrometer relay; the color separation is done radially by lateral chromatic aberration.
Normally the slit of a spectrograph is a line; here instead it is a circle.
Can be used to monitor the Sun corona, or for spectral imaging.
Lateral chromatic aberration, which normally we don't like: unbalancing the color correction around the aperture stop - overcorrected on one side, undercorrected on the other, the colors separate.
Similar to a prism spectrometer. The overcorrected/undercorrected lenses do the same job as the dispersing prisms, but do it radially around the axis.
It works well in the visible range, but limited in the UV because of how color dispersion work in glasses.
Some researchers want a similar setup for a small coronagraph telescope to be sent in orbit. But using a circular diffraction grating instead of the glass dispersion.
CISS - Circular Slit Spectrometer - Landini - Frassetto INAF
https://indico.ict.i...derico_CISS.pdf
The circular diffraction grating has more dispersion than the glass and works ok into the UV.
But is more difficult to fabricate, has haze, many orders of diffraction, unchartered aberrations...
My setup:
Achromat objective - can be a telescope or a camera objective. I've used a standard 50mm f/1.4 camera objective that was around.
It forms image on a plane, where you put the circular slit
I've made the circular slit by gluing aluminium foil on the flat of a flat-convex lens, then cutting the slit on a lathe with a knife.
After n attempts it come out decent, about 0.03 mm thick.
The circular slit can be otherwise ordered litographed for some 100$
The flat-convex lens works also as field lens, collecting the rays.
As dispersion lenses, I had around some overcorrected triplets, likely from Ortho eyepieces. Use two of them.
Aperture stop, very small
One undercorrected singlet lens
Sensor
Rough sketch of the setup
Raytracing of the relay; the telescope objective should be on the left; this raytracing start with the intermediate image and slit on the left, then the field lens, then the two triplets, stop, singlet, sensor.
Axial chromatic aberration is corrected.
Lateral chromatic aberration is instead very strong, about 1 mm.
Because of stock/ pillaged lenses, it had to work with small aperture to get decent imaging (ca. f/20 on sensor). The lateral chromatic is visible in the raytracing::
Edited by patta, 04 February 2025 - 03:40 AM.
