Yes there were different versions of the Moonfish 30mm
However, it was never labeled Meade and never had yellow lettering.
Is this simply a misidentification of the eyepiece?
The Moonfish 30mm eyepiece was also sold as a BW Optik 30mm, Smart Astronomy, Knight Owl and 1rpd (Astrobuffet).
I tried one many years ago in an f/6.5 scope, and it was simply not good.
Moonfish versions of the 30mm:
https://stargazerslo...mm-help-needed/
https://www.worthpoi...piece-422983739
https://www.amazon.c...B09ZTQWQC5?th=1
https://www.cloudyni...-uwa/?p=3487493
**Reading more deeply, it seems the company that imported and sold eyepieces under the Moonfish name did import a line of 70° eyepieces, in 10mm, 15mm, 20mm, 25mm, and maybe 32mm.
and it is possible they private labeled the same eyepieces Meade had contracted after Meade had gone to China for their S5000 SWAs.
I found this note from the people at Moonfish:
Posted 10 November 2005 - 08:43 AM
The Ultrawide 30mm come from the same assembly line as the 1rpd, and they are nominally 80 degrees afov. The Moonfish version has the M49 camera thread cut into the top, plus the rubber eyecup to collect the rain water we have to put up with here in Europe.
The 70 degree versus 80 degree confusion arises often: The 30mm Superview eyepiece (a completely different eyepiece entirely, from the GSO factory) is about 70 degrees afov, and tends to edge perform better at less than f/6. The 30mm Ultrawide is happier at f/6 and upwards. Both are quality/cost bargains of some repute, and we just happen to sell both under our own brand. But hold them in your hand, and there's no mistaking the difference; the Ultrawide is built like a tank, and you'd regret dropping it on your foot, while the Superview feels much more like a standard 2" eyepiece.
Hope that helps,
Ric Capucho
Moonfish Group
So perhaps the 32mm is a GSO. GSO did make some eyepieces for Meade at one time and has made private label eyepieces for many makers.
Edited by Starman1, 05 February 2025 - 03:09 PM.
