No replies to this topic
#1
Posted 05 February 2025 - 11:13 PM
Not overly sure how to describe is, but my HEQ5 RA axis is rather stiff in some spots, which makes balancing a bit hard. I bought the mount second hand, and noticed it when balancing. I thought it would just be the bearings, to which yesterday I replaced all the bearings in both axis’, but this didn’t help with the stiff spot. I noticed the stiff area kind of changes when I adjust the two worm engagement grub screws. I’ve change the preload on the tapered bearing, which didn’t help either. I used an abrasive to try and remove some material off of the worm gear casing (not the actual worm gear), because I thought they may be colliding at some point. I’ve cleaned everything, I sanded some paint off of the connection point of the worm gear casing and the plate. I feel like I’m running out of ideas. The mount it smoother with the new bearings, but it’s still stiff in a location, that can change based on the tightness of the two engagement grub screws. The grease I used was Parktool Polylube, which I was told was fine to use. Any advice will be greatly appreciated.
Also tagged with one or more of these keywords: Mount
Equipment Discussions →
ATM, Optics and DIY Forum →
1990's Meade 10" Starfinder: Simple DIY Upgrades (& Questions)Started by dr_gn , Yesterday, 06:04 PM ![]() |
Equipment (No astrophotography) →
Putting a Synta EQ1 to Good UseStarted by dmgriff , Yesterday, 05:18 PM ![]() |
Telescope Specific Forums →
Meade Computerized Telescopes →
ETX-90 Tube Rings Source FoundStarted by tg_quigley , Yesterday, 02:13 PM ![]() |
Mounts →
OG Star Tracker V2Started by Rince , 13 Mar 2025 ![]() |
Mounts →
Help setting meridian flip on NINA with Losmandy G11Started by francomeconi , 12 Mar 2025 ![]() |
